DreamBox not connecting to Internet
  • saxson99
    • 7
    I have been able to update the Roms on my Dreambox, using CuteFTP, the setup is through a router, but when tring to add new emulators on the Dreambox using the update, it does not connect to the internet.
    I am using DW ver 2.
    Any ideas would be much appriciated.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Is your default gateway set to the ip address of your router?
    What is the error you get when trying to download from the addons menu?
    Maybe try doing a factory reset and try again.
    Remember to save your services and bouquets first! You can do this by going to the User Features menu and select 'ServicesBackup'. You will get a 'services.tar.gz' file in the /tmp folder, copy this to your PC. Do your factory reset, setup your network settings, copy the services.tar.gz file back to the /tmp folder and select the 'ServicesRestore' option in the User Features menu.
    Then try to download from the addons menu again.
    • saxson99
      • 7
      Thanks for your feedback Kaos.
      The error I am getting is 'Can't resolve hostname!,
      Thanks for your help.
      • jjbull
        • 42
        did you get this sorted as this is the problem im having
