Freeze
  • sooncome
    • 8
    Freeze
    Hi all
    Is any one having this problem, all the Satan** channels freeze after your watching them for a while, I have checked the frequency and it?s on the same one as my Eurovox and this problem does not happen on that box.
    Any ideas
  • trickykid
    • 89
    Originally posted by sooncome
    Hi all
    Any ideas
    what cam are you using?
    • sooncome
      • 8
      Freeze
      i'm using evo cam 2.12
      • trickykid
        • 89
        that's weird, cos i'm using the same cam and have no problems at all. The reason i asked for the cam is because i was using mgcam and channels were freezing all the time, but not with evocam. Sorry, don't know
        • bugaloo41
          • 1598
          Think this is area dependent. I have a similar issue with sky sports 1 and 3. I use a 6db attenuator (?2 from ebay buy a variable and you can adjust signal strength) and plug this into the cable and it works a treat. Other people use a signal booster.
          Worth a try is deleting the channels then doing a bruteforce scan again. It may make a difference.
          • sooncome
            • 8
            Freeze
            I have tried deleting the channels then doing a bruteforce scan It worked for a while.I will buy a variable and try that
