black screen on dreambox
  • jevo1965
    • 11
    flashed nagrarom7.bin as image by mistake can it be fixed
  • thommo
    HOW THE HELL DID YOU MANAGE THAT LOL........
    use dream up and null modem lead and reflash it with an actual img,
    oh and dont do it again .
    • jevo1965
      • 11
      got dream up and what i think is a null modem cable it says connection prepared switch on box but the flash option doesnt highlight
      • aftermath
        • 4345
        How could that file flash m8, its a bin file, not an img file. ?
        • thommo
          when you connect leave the power to the dreambox off, when you click connect it will say waiting for dreambox, plug your dreambox in then....should say dreambox is alive and talking to us after that then you should be able to flash.
          • jevo1965
            • 11
            i was using dreambox control centre
            and image and rom bin files are supported they were all in same directory and clicked wrong file
            • aftermath
              • 4345
              to flash an image it has to be an .img file , if you tried to flash a bin file it would tell you , invalid file.
              • jevo1965
                • 11
                it has option to update flash image which supports rom bin cramfs img files
                • smedzdave
                  • 71
                  check out the dior image with au-roms have uploaded in the download section ok.
                  download itand flash it to your box ok.
                  when it asks do you want to perform a flash erase just click no(nein) ok.
                  then after connect everything back up and
                  scan for the channels using bruteforce first,
                  So do the following
                  language english
                  save
                  time settings click the down arrow on the screen and choose your time settings.
                  then click save
                  then choose automatic transponder
                  choose bruteforce
                  wait untill you see start scan (But dont click only free)
                  then wait for the channels to download
                  then go to
                  menu,
                  service searching
                  choose cable 6887
                  wait till it says start scan (again do not click only free)
                  then after it has finished click exit 3 times.
                  go to sky sports 1.
                  everything should be working fine then ok
