How to change COM port settings using USB-to-Serial Adapter
  • smirnoff_rules
    • 8603
    setting to change your com settings
    Start -> Control Panel -> System -> Hardware -> Device Manager -> Ports (COM & LPT) -> Prolific USB to Serial Bridge… at this point, take note of the COM number. Use that number when assigning the COM port
    in your Device Manager and double click your USB to Serial adapter. Click Port Settings and then Advanced. You should then be able to select the COM port (1, 2, 3, or 4) being careful not to select a COM port already in use on your computer.
    if u only have printer and com then change the com one in the drop down box
  • markbng
    Changing com-port number with some drivers with fixed com-port
    Some virtual com-port drivers seem to have a fixed com-port number. These drivers mainly use usbser.sys from Microsoft. You can change the inf-file of the device....
    [USBtoSer.AddReg] ; AddReg section
    HKR,,DevLoader,,*ntkern ;
    HKR,,NTMPDriver,,usbser.sys
    HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropP ageProvider"
    The USBtoSer label can be different from your device. The last line is important. Please make sure that msports.dll is included in the inf file. After you have reinstalled the driver, you should be able to change the com-port number.
    Regards,
    Mark
    • simski100
      • 19
      Null modem on usb not working
      I have just bought a usb adaptor for my null modem cable as my laptop doesnt have anywhere for it to plug in but it still aint working. cant see any com ports in harware manager but a usb ser! whatever that means. So I cant flash my dreambox 500c with a new image. I am at a complete loss as how to get round this so I need some simple advice.
      • foxhill
        • 9
        I m in same boat. bought one adapter from ebay. but it didnt work out. tried evrything. later discoverd- after installing the driver for adapter andplugged in USB, windows automatically startts downloaded the driver for adapter, though I already installed one.
        so think few these adapters r dodgy, especially bought from china!! and there is no drver support.
        well still no luck. goin to fork out more few quid on good one this time.
        any progress pls keep updating
        • jimbo69jones
          • 64
          A lot of the cheapy USB>Serial adaptors sold on ebay use a TI chipset, and the drivers can be hard enough to find alright. I've attached the drivers I managed to find and I hope they help. They are actually for a USB>Mobile serial phone lead, but they have worked on several non-branded serial leads as they use the same chipset. Cannot hurt to try.
          • andyd123
            • 61
            Like many i bought one of these for flashing my 500C from my laptop.
            I installed the software and it automatically installed to com10. i changed from com 10 to com 2 as 2 was free but to this day i could never connect to the 500c using this cable instead wen i need to reflash i use a friends pc.
            If there is a solution to this i'd be very interested.
            Andyd123
            • smirnoff_rules
              • 8603
              have u tried dreamup for the 600 pvr its abit better l have found and auto finds the port
              • andyd123
                • 61
                I can only find one version of Dreamup which seems to be universal for all models.
                Thanks for your reply
                Andyd123
                <--andyd123 added 12 Minutes and 25 Seconds later...-->
                I just downloaded the latest dreamup 1.3.3.0 and now if i connect the box via the usb to com adapter the box gives the following message then just stops and goes no further
                23:18:19 box type: DM500
                Any further ideas ?
                • alliv
                  • 299
                  i had this problem with my laptop and vista.
                  is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
                  • wholesale
                    • 12
                    USB Null modem cable
                    I have one of this usb null modem cable whick works ok with eurovox but does not detect dreambox and when i try to use this cable with dreamup laptop window vista crashes.
                    • Dazza
                      • Aug 2008
                      • 59
                      I've got one of these adapters for my lappy, but it's never worked properly.
                      The drivers installed ok on XP, and I can change COM ports just fine. Dreamup seems to id everything ok, but after that, nothing works.
                      Same in Ubuntu (Linux OS) It picks up the adapter just fine (no drivers needed!) but again, Dreamup seems to have issues.
                      I wonder if it's more of a power issue when using the adapter...?
                      • mrcraig
                        • Aug 2008
                        • 16
                        i have one of the usb adapters to flash my starview 3 ..that was simple..but im lost when it comes to a dm500c...HEEELLLPP
                        • Dazza
                          • Aug 2008
                          • 59
                          See the first post in this thread, and use DeamUp.
                          What's the problem exactly..?
                          • sherlock
                            • 35
                            Can confirm that these adapters from ebay do not work on a laptop running vista.
                            best addapter is a pcmcia to serial card works no probs 500/600/ev too,
                            Just ensure it is vista compatable.
                            • andypandy
                              • 47
                              I have same problem. Did you solve it?
