need a services.xml file for ch**us mmds, can anybody help?
  • tmontana
    • Jul 2026
    hi guys, i recently bought a blackbox 500T for a ch**us mmds terrestrial setup (im in kildare) anyway i scanned and got the channels ok but there are quite a few missing including bbc1,bbc2,utv,channel4,sly sports2 to name a few. at first i thought it may be a signal issue so i brought box to my neighbours house and scanned there and still cant find the channels. this is really strange because i have setup alot of these mmds boxes and never had this issue, so im asking if anybody has a fully functional 500t box working can you please upload the services.xml file for me so i can get the last of the channels im missing
    also i would be interested to know if anybody knows a reason why im not picking up these channels, maybe the terrestrial.xml file i used to get the ch**us scanning options is out of date?
    maybe ch**us have shuffled around their channels and frequencies?
    would love to hear from you
    cheers
    Monty
  • bugaloo41
    • 1598
    terrestrial file here mate if it helps Digital Kaos - Downloads - Services and Bouquets
    no idea if its more up to date than the one your using mind.
    • glic83
      • 329
      there has been issues with the tunners of the clone 500t's for a while now if you are missing channels its because of a hardware fault there is a weak spot on the tunner you can use a different downconverter a if622 will bring the channels in at a higher freq and you will get everything then
      • tmontana
        thanks for the replies guys
        glic where can i get one of these if622 downconverters and how much am i looking at? are they easy to install?
        will it involve me getting up onto the roof to attach it?
        say i got a working services.xml file and uploaded it, would i still not have the channels?
        cheers for your replies
        monty
        • alliv
          • 299
          yep i think you will find that the tuner is weak on freq 266000 and thats where. the channels are that you are missing
          is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
          • red devil
            • Oct 2008
            • 690
            u can get it here Integrated MMDS Downconverter WITH POWER SUPPLY - Bubble Cable Boxes Online Store but u need to scan on a higher freq and u will get all the channels, when u have this aerial do a scan and let us know how ur doin.
            • alliv
              • 299
              monty
              mate scan the freq 266000 and see if you get any extra stations if not then buying a new aries or downconverter wont help as the problem is in the tuner in the box.
              • glic83
                • 329
                it will give him the extra channels as the if 622 downconvertor will bring in the channels on a higher freq so instead of it being 266 it will be on 722,all the channels will be on a higher freq,you will need a different terrestrial.xml also
                • tmontana
                  guys if any of you have all the ch**us mmds channels , would you be so kind as to upload the services.xml file for me so i can give that a go and see if i get the channels
                  much appreciated
                  • despdan
                    • 544
                    much appreciated
                    try this terrrestrial.xml i know it works its my own, did you get a new downconverter? if so what is its rf output?
                    Digital Kaos - Downloads - terrestrial.xml
                    • Ginkman
                      • 93
                      tmontana,
                      if I ever get the service file out of my 600T I will send to you, just can't find it bud. I could get you one from a clone 500t but it would be missing the channels,
                      please list all the channels you are missing. The old clone t problem missed 4 channels, bbc1 bbc2 ch 4 & utv. They are on the frequency as explaned by the guys above, if you are missing more than that, then it is a worse or different problem. I am curious about this issue appearing on a Blackbox as the Chinese suppliers are promoting the Blackbox over the 500T at a slightly higher price, because they say it has a new genuine tuner and gaurantees no missing channels. I would send it back for a replacement. We have got some 500T's from dvbseller recently and they were 100%, no missing channels.
                      I've got two DM600PVR doorstops...
                      • despdan
                        • 544
                        services mmds
                        inside this youl find a copy from a 600t pvr dont know if they will work in a 500.
                        you could try cut n paste
                        • tmontana
                          thanks for the replies guys, i still havnt got the downconverter although i think that will do the trick
                          just had a lengthy conversation with a board member on msn and he tells me that the downconverter will get me the missing channels
                          the channels im missing that i know of are bbc1,bbc2,utv,channel4,sky sports 2, there maybe more
                          @ desp dan, thanks for the file, ill try it
                          i dont really want to send it back to china because the postage will be expensive and i run the risk of the replacement being the same.
                          • despdan
                            • 544
                            if you open it with notebook you will see a list of channels & freqs
                            • tomhick024
                              • 559
                              Glic83 is spot on with his answer! Some boxes have a dead freq band and getting the downconverter whick brings in freqs higher is the only way to fix this problem - as i have proven with his help!
                              T
                              Whatever!!
