DM800HD web interface failure after plugin update
  • hmanxx
    • Mar 2010
    • 11
    Hi,
    Received a gift from friend..DM800HD PVR (Clone),image release is rather new (26/1/2012), after playing for it for a few days..getting itchy hand go update the "web interface plugin ", eversince then..the interface dead..can't connect to the web interface..my android phone control also dead. Rebooted many times, uninstall /reboot/install repeated many times cant get it to work.
    Image:Newnigma2 v3.2.1 2011-05-04
    Enigma:ramiMAHIER-experiment
    The FTP interface is still working..I have backup /scce , /keys, /enigma /bouguet folders however didnt back up the initial plugin..
    Question
    1) How to see the web interface plugin (web server) service is running ?
    Any kind soul has a proven working webinterface plugin for DM800HD PVR ,please send me a copy...
    Avoid going to the route of master reset which i foresee will see more problem.
  • madas26
    • Apr 2010
    • 18
    have u tried holding the power button on the box till it says stop then trying it ? if worse comes try using dream up and reflash
    • ahbenghero
      • 32
      Try to install tspanel, in the addons menu, there is a few web interface plugins..I used to do force install for webinterface patch done by mfaraj..
      • hmanxx
        • Mar 2010
        • 11
        I managed to find one patch to work.but not perfect..at the end applying mfaraj patch..after reboot ..completely blank screen..boot looping..FTP still working..no choice now have to do image update
        • ahbenghero
          • 32
          use telnet to do installation force-overwrite with the patched webinterface plugin...
          remember you need to clear your browser's cache before keying in you ip address again...
          • hmanxx
            • Mar 2010
            • 11
            thanks, the likely problem was my ignorant to uninstall language (German) pack to free up memory ..that proven to be no return road causing boot looping @ SSL stage
            Anyway, I managed to load in another ROM to get the box working again..exhausted..havent recovered from panic stress..
            Question.
            Can you put up clearly on the exact commands of force installing..
            • ahbenghero
              • 32
              Question.
              opkg install /tmp/*filename.ipk* --force-overwrite
              remember to ftp the file into your /tmp folder first
              you can go find the language pack you deleted and install it back using this way.
              Im not too sure whether deleting language pack will cause boot looping...did you do anything else??
              • 2echo
                • Jan 2012
                Check your DHCP and your web interface IP Address.
                • hmanxx
                  • Mar 2010
                  • 11
                  thanks alot for the information.. Lesson learnt is never touch those addon update if nothing break..and do not uninstall system stuff...I did uninstallation of german language..after that..just keep boot looping..
                  I am hopping to other websites to pick up piece here and there..
                  • stephane2013
                    • Feb 2012
                    DM500C Without image in screen
                    I do all for working DM500 C.
                    Nabilosat DarkstarII CCcm 2.2.1
                    But i have any images in TV?
                    Help please
                    • stephane2013
                      • Feb 2012
                      Help a need Help
