Hi there once again please could you advise i accidently crashed couple of dreamboxes at the early stages when there was limited information by changing images via router now obviously i get blank screen and no access to ip address would i have to use a null cable or do i kiss them goodbye and does router and null cable give you different access or do there work both the same thanks
crashed after flashing
99% of the time you will be able to flash it again but you will need to use Dreamup and a null modem cable.
There's a guide here...
How Do I Use Dreamup? If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug
Once you flash the image you want, setup the ip address again and copy over the new AU files.
