When trying to flash my dreambox with dreamup all goes well until I hit the connect button, then it says connection prepared switch on power, and tells me the time and that it a box type DM500, then the only thing highlighted is disconnect. I am using a null cable which I verified by doing a continuity test. Any help would be appreciated.
Trouble flashing with dreamup
wot image r u using m8 is it a new install or reflashWhen trying to flash my dreambox with dreamup all goes well until I hit the connect button, then it says connection prepared switch on power, and tells me the time and that it a box type DM500, then the only thing highlighted is diconnect. I am using a null cable which I verified by doing a continuity test. Any help would be appreciated.we are all learning each day -
we are all learning each dayComment
Sorry I am not making myself clear dreamup is not letting me do anything it goes to connection prepared connect power, then in the Log it tells me the time and box type DM500 . All the buttons are grayed out except disconnect. I feel I've not got the set up quite right.Comment
Sometimes a slow gradual approach does more good than a large gesture.Comment
