Dreambox Ireland
  • davidmull02
    • 22
    DM500 Dreambox Ireland
    Hi ,
    My DB on the blink. Its just dispalying a blank screen, Are the new Roms out and if so where can I find them or is there just something more serious up with my DB?
    Thanks!!!!!
  • despdan
    • 544
    when did you last change the roms?
    can you see the epg?
    • davidmull02
      • 22
      Box just keeps rebooting.
      Hi
      Oh! No! Looks like my issue is a little more serious then just a update roms issue. Looks like a software related issue not sure. What is happening is that the box just keeps rebooting every 10 seconds, which means that I cannot ftp or cannot telnet into it either. Which also means that I cannot restore my backup or basically do anything with the box. Sooo I am pretty much stuck with a box that is not working and not allowing me to recover it. Any one got any suggestions that I can try?
      Cheers!
      Dave....
      • despdan
        • 544
        flash your backup with dreamUp no to flash erase
        • davidmull02
          • 22
          Thanks I will give it a go, Do I have to use a Null modem cable? Would a cross over cable work?
          Cheers
          Dave.
          • Digger
            • 154
            i've only ever used a null modem cable, think u can only use that, a cross over cable can be used for ftp to the box i think
            • gizmo.1484
              • 873
              Cheers
              Dave.
              If you are using dreamup then you have to use a null modem cable you can only use a x over cable to ftp to you box
              • Spencer024
                • 11
                If you haven't got null modem, you can make one up yourself, it will work if you cross pins 2 and 3, or build the one which incluides handshaking
                RS232 serial null modem cable wiring and tutorial
                Rgds
                Spencer
                • rickets
                  • 135
                  If you cant use dreambup you will have to go down the jtag route. I am in this stinky boat at moment and am ordering a pre made jtag shortly.
