stuck..
  • jedimaster1878
    • Feb 2012
    • 31
    stuck..
    connection prepared now switch on the dreambox...but nothing happens when i connect the dreambox
    aarrggghhh heads battered am in the process of going through each version of dreamup any help would be majorly appreciated
  • mtv1
    The Stig PT
    • 4413
    try dcc the dreamup below works on the 500
    • jedimaster1878
      • Feb 2012
      • 31
      says them files no longer available mate
      • mtv1
        The Stig PT
        • 4413
        sorry mate
        • jedimaster1878
          • Feb 2012
          • 31
          cheers for that..ive already used that version to no avail..
          as im new to this ill give you few details..
          comport6 usb null modem also
          follow the guide albiet stiill at stage1/2 then nothing..the boxes are new out the box so wondering if ive missed something..again any help much appreciated
          • preditor
            • Nov 2011
            • 82
            u haveent installed the null modem drivers
            Discussions about cardsharing are not allowed...
            Discussions about hacking or modifying cable company equipment will be removed.
            • jedimaster1878
              • Feb 2012
              • 31
              there was a disc that came with it, i installed the drivers for win7, and when checked says device working properly..is that what you mean??
              • mtv1
                The Stig PT
                • 4413
                usualy com port one are you using a lap top or tower ??do NOT connect the Ethernet cable while using dreamup
                • jedimaster1878
                  • Feb 2012
                  • 31
                  have tried on lappy and pc both with no joy..
                  none of the usb ports are comport 1, lowest was 5 i think going upto 12..
                  got no ethernet connected at anytime altho both are connected to internet wirelessly
                  heads frazzled
                  • jatrophaseed
                    • 589
                    heads frazzled
                    Can set comport to Com1 in comprt property. Use 'right click.' dats 378 i think.
                    • jedimaster1878
                      • Feb 2012
                      • 31
                      when i do this it says cannot open port when i open up dreamup??
                      • jedimaster1878
                        • Feb 2012
                        • 31
                        ive now got just the null cable attached without the usb to an old computer..com1 on dreamup yet still says connection prepared plug in dreambox hheeeeellpppppppppppppppp
                        • mtv1
                          The Stig PT
                          • 4413
                          sounds stupid but not so long ago i had that problem it was the power supply i tried an old xmas 12v adapter i had in the attic worked a treat pm sent if you need more help also use the old pc those usb adapters are shiote
                          • jedimaster1878
                            • Feb 2012
                            • 31
                            have pm,d you back..it seems its finding the comports linking up just nothing when says connect dreambox..you mean the power adapter for the dreambox??
                            • jatrophaseed
                              • 589
                              My innocent question.
                              hv u chk the 2 female ends dat:
                              piin2 A side connected to pin3 B side
                              pin3 A side connected to pin 2 B side
                              and pin5 to pin5.
                              ( dats nul cable connection ).
