How do i stream my PC with my dream box ? I've tried using VLC but i can't seem to get it to work. It will show screen shots but won't stream.
How to stream
Yes, that's correct.
Although the dreambox will only decode MPEG format. So if the movie is in avi/divx/xvid, like most are these days, it will need to be converted to MPEG first.
Or you can use VLC to transcode the file 'on the fly' as it's being streamed to the dreambox. The convert to MPEG would probably be less hassle.Comment
If you are using a Gemini image you can use the VLC Frontend Plugin.
This allows you to specify a particular folder on your PC containing your movies )avi, wmv, mov etc) and access and play them from the Dreambox remote.
I use it and I think it's fantastic. I'm not sure if it will work on images other than Gemini though. Perhaps someone else will know?Comment
Like I said if you are using Gemini then the VLC Frontend is your best option.
Here is a link to a guide on how to set it up:
Like I said earlier I don't know if this will work on images other than Gemini. If your image is Enigma based it should do in theory.
Please let me know what image you are using so I can try to help.Comment
search google for vlc 0.8.6b download that mate.
dont download any newer than the "d" version though, ive heard peeps having probs with it.
once you install it, enter a command in your web browser http://192.168.xxx.xxx/?screenWidth=1280
the xxx.xxx you need to change to your IP on the dreambox.
you will get a screen showing your channels/bouquetts click on the web-x-tv link , top left hand side.Last edited by aftermath; 25 April, 2008, 21:26.
