keys
  • jedimaster1878
    • Feb 2012
    • 31
    keys
    ok ive successfully flashed my d500c thanks to help on here..now i just have black screens so need help with files for keys and understand have to connect comp,dreambox and router together..do i use null from comp to dreambox then crossover to router from dreambox..thanks
  • jatrophaseed
    • 589
    Send to DB with FTP software.
    Filezilla is 1 of them, you can use any you r used to. Go to dl section for/choose your liking.
    DB direct to Computer use CROSS Rj45 cable.
    DB via router to Computer use STRAIGHT Rj45 cable.
    • jedimaster1878
      • Feb 2012
      • 31
      ive got a crossover cable..is the straight one just normal ethernet cable that comes with your router???
      sorry i take it i only need to do one of the above to connect up not both
      • jatrophaseed
        • 589
        Yes, usually the str is come with modem or router. If yr eyes r gud, compare the 2 ends, if colors r same in the 8 slot for both Rj45 plug, it str, if the 2 plugs with colrs seen not the same in the same slot of 8, then prolly it X.
        • jedimaster1878
          • Feb 2012
          • 31
          ill have a go at that after feeding time..any pointers were i can get the keys from?
          • jedimaster1878
            • Feb 2012
            • 31
            ive just had a quick go at it and got the message "error 10057 in function send socket is not connected"
            any ideas how to resolve this??
            • jedimaster1878
              • Feb 2012
              • 31
              hey guys ive got dcc up and running yet the keys i have i transferred over yet they not showing up on DB after reboot and still only FTA channels..what am i doin wrong???
              • DBTraitor
                • Feb 2011
                • 616
                do you have the correct cam?
                A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                • jedimaster1878
                  • Feb 2012
                  • 31
                  not sure..as a noob ive just flashed it with 1.1 then used DCC to transfer files altho nothin changed..how would i check this regarding cam
                  • jedimaster1878
                    • Feb 2012
                    • 31
                    ive transferred the scce successfully but when i look in var/keys there is nothing there even tho when using DCC it shows they are there...i have evocam2.12 if this helps
                    • DBTraitor
                      • Feb 2011
                      • 616
                      you probably need to transfer the keys again
                      • jedimaster1878
                        • Feb 2012
                        • 31
                        ive reflashed the box, sent keys over again rebooted etc yet still black screen..aaaarrrrrrrggghhhhhhhh...pms grateful
                        • DBTraitor
                          • Feb 2011
                          • 616
                          Can some seniors provide some assistance to jedimaster1878 on his problem.
                          jedimaster1878, Which country you from by the way?
                          You have the right keys and files for your area?
                          • jedimaster1878
                            • Feb 2012
                            • 31
                            thanks DB im in UK(liverpool) not sure bout upto date keys etc...reading thru last night i havent schmod to 755 so gonna give that go later..any senior help would be much appreciated still..
                            • DBTraitor
                              • Feb 2011
                              • 616
                              Hope you get it resolved soon
                              Here is another thread talking abt dreambox for liverpool
