Adding channels to DB500c bouquets
  • nemo
    • 14
    I recently reflashed my DB500C with the DK1.1 image.
    All is fine...i just wanted to know how i can speed up the process of what the channels are. It is a painstakingly slow process to add channels to bouquets as unlike the DBox2 all are in numbers and letters and it seems a long process to set your bouquets up.
    Any help will be gratefully appreciated.
  • Sirus
    • 340
    If you adding them through the folders way, that IS painstakingly slow
    Try DreamboxEdit, you can set everything up using that and FTP the bouquets into your Box(Ive never used it though)
    If you want to use your remote then the fastest way to add channels to bouquets is to use the "All Services" list(like one big bouquet in alphabetical order) thatll always be there and once you have created your bouquets you can jump from your All services mode to bouquets mode by pressing OK then pressing either RED for All services or BLUE for bouquets mode
    Once youve made your bouquets all you have to do is when in your the all services list just press the setup button when highlighted the channel you want to move to a bouquet and youll see a menu..itll say add this channel to specific bouquet then pick the bouquet you want to add that channel to then repeat until all channels are in the bouqueta you want them in... to organise them switch to bouquet mode and go to a bouquet you want to organise same again press setup once highlighted a channel this time go to enable move mode and press OK to move that channel where you want it in the bouquet and repeat till all your bouquets are all organised
    Sounds like loads or stuff just to setup channel lists but once you pick it up its a fast enough process
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      There's a guide here...
      Digital Kaos - Downloads - How To Setup Bouquets on Gemini and Enigma Images
      • nemo
        • 14
        Thank you very much...i'll get on and read that guide.
