I have had this problem on a number of the boxes, There is a easy fixx for this, it transpires that the IR sensor is not in the perfect position for receving the signal, so open the box, there are two clips on the top front cover, remove the ribbion cable before doing this, make sure you know the correct way to plug the cable in, "look at the red stripe orinantate from that" then on the IR - LED - Power button PCB there are three small screws take them out and the PCB you will notice the IR Sensor and generally its bent back on the board or bent away from the board, you need to get this paralell to the board so it can see out the tiny IR window if you do this it will solve the issue, if you are really brave desolder the IR sensor and hot glue it to the window, extend the leads to the board this really fixes the problem.
fake dreambox's
hi mate to get your box a life again you to fixe the bootloader and this by using the jtag all you need is on this link http://www.digital-kaos.co.uk/forums...do=file&id=193 gd luckComment
