web interface
  • tomhick024
    • 559
    web interface
    Wondering if anybody can help me! Doing my head in.
    Trying to stream dm500 to my laptop -used to be able to access web interface page before, but now for the life of me i cannot!
    Checked in expert settings - ip dreambox is correct,
    DHCP - enabled
    Netmask is correct for my router.
    Namserver and gateway is ip of router.
    Enable network is ticked and port is 80.
    When i enter ip of dreambox in browser, comes up with prompt for username/password = root/dreambox.
    Them i get error 'HTTP 404 Not Found'
    Anyone got any ideas!
    I also tried flashing with old back-up image and no difference.
    Thanks in advane
    T
    Whatever!!
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    If you are getting the username and password box then it sounds like the connection is there and ip address is correct.
    Maybe the http deamon isn't running on the dreambox.
    What image are you using?
    • tomhick024
      • 559
      Hi Devilfish,
      Thanks for coming back to me, tried first on DW2.1 then reflashed with version 2.0 and still the same thing, the dhcp box is ticked and as you say ip is def correct, must be some other setting that i ~~~~ed up but cannot find it!
      T
      Whatever!!
      • Aldormanndiobla
        • 54
        Can you telnet onto your dreambox, if you can, type ps -ef and see if the web daemon is running.
        Scrap that, if you have the username and password prompt, the web daemon is running. (too many beers last night) reflash it with dk1.1 and see what happens.
        Also, would your firewall on the pc be blocking anything?
        Real men have FTTH.
        • caveman_nige
          • Feb 2008
          • 4920
          take down your firewall for a while if that does not do it delete the cookies and temp internet files from your browser..
          • tomhick024
            • 559
            Thanks for the suggestions gang - will have another go tonight when i get home!
            Must be something to do with firewall, not a top hand at this kind of stuff but will try what I can.
            Cheers
            Whatever!!
            • tomhick024
              • 559
              tried all suggestions so far, turned off firewall, also cleared all history , made no diif, will build new dk image over weekend - wife starting to nag!!
              Whatever!!
              • tomhick024
                • 559
                Can anyone tell me what folder i put my cable.xml file in to please?
                T
                Eventually got image working, took me a while to find how to start cam(info button - was blue on DW2.0) but i'm def stuck now!
                After browsing tonnes of posts, i still cannot figure out how to restore my bouquets from my dw image backed up with dreamboxedit! I have tried 'send file to dreambox' but not sure if i'm selecting the right ones and if the path is correct!
                Can i just ftp them to a particular folder?
                Must /can i restore them with DBE?
                Some help please as i'm not far away from being completely sorted!
                T
                Whatever!!
                • tomhick024
                  • 559
                  Well, sorted bouquet by manually adding them, could not use ones from DW2.1 backups via DBE!
                  Last thing now is to get it recording to laptop!
                  Happy days!
                  Whatever!!
