Is this the JTAG conector?
  • despdan
    • 544
    DM600 Is this the JTAG conector?
    Can anybody PLEASE confirm that this is the JTAG on the dm600 ? bottom right corner of the box
    Also is it wired exactly the same as the dm500 ?
    many thanks
  • Cello
    • Apr 2009
    many thanks
    I also need to have an answer to this question due to my dm600 died yesterday I pressume it died due to low voltage on the powersupply & flashing with low voltage.
    //Cello
    • TopGun
      • 68
      Not sure, but i have heard a null modem cable and dreamup will do the trick.
      • Cello
        • Apr 2009
        Hi again
        Foundout that the picture is infact the jtag connect. And that the layout is same.
        I checked the layout of the connector and as far I can see its the jtag connector, and that the layout is same as for DM500.
        see here www.dreamboxx.se/pdf/pdf/DM600_logo.pdf
        My problem is now solved, but I did not need to use the jtag connector. I simply had connected the front connector wrong when trying to understand why my box did not work. My problem was from the beginning dying power supply. So now it works again (no strange behaviour when starting up, no picture feezes, etc ...)
        //Cello
        • pluto2013
          • Aug 2009
          • 297
          hmz does it works?
          • joejoe77
            • Mar 2010
            thank you
            thank you for your work
