dm 800 won't start
  • fotsirk69
    • Jan 2012
    • 18
    dm 800 won't start
    hi guys,
    i need your help badly. i've just upgrade today to dm800c hd pvr with nabilosat image instaled. when i started up everything seemed to be fine but then when at some point screen asked me "do you want to download updates" i press "yes" and then "do you want reboot now" again "yes" and...
    and that's it box doesn't respond at all to remote, to the button also and after re-start on box screen appears only "dream multimedia". I've try to use dream up to re-flash but no connection, even when i've check router there is no more dreambox connected
    Any idea what could hapened and what i might do to bring it to live.
  • DBTraitor
    • Feb 2011
    • 616
    do u know how to use web browser to flash?
    Connect your box to internet, Open web browser and enter IP address of the box on the URL.
    Select Firmware upgrade
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • fotsirk69
      • Jan 2012
      • 18
      i cannot use browser bcos box isn't appear on router connection list. i cannot get into it and don't know why.
      what else can do?
      • kegsie
        • 27
        Switch off box, press power button on front and hold power up box, on small screen should say stop then ip address will come up. put this ip into your browser and enter. then upgrade firmware with your new image. thats it.
        • fotsirk69
          • Jan 2012
          • 18
          done it many times but nothing. power buton don't responde so only how i can switch it off is puling out power cable but when i power up again power buton (red led) flashing three times and on small screen is same msg again 'dream multimedia' and that's it.
          • ypvs125
            • Dec 2010
            • 506
            Is there any error display on the front lcd like dreammultimedia ERROR! or dreammultimedia ERROR 01 NO CA? First error may be due to yr sim card faulty while the second, u need patch dreamup to recover yr box or optiflasher.
            Digital Kaos - Downloads - Dreambox NO CA FOUND Repair Tool SIM2 EDition V2.5
            Digital Kaos - Downloads - DreamUP Patched dm800 clone
            • Jimdefruit
              • Apr 2012
              • 33
              Are you powering off for long enough?
              You need to switch off mains for at least 10 seconds. Then hold the power button on the front of the box and keep it pressed whilst switching on the power. Keep the button pressed until you get the message "stopped" and the IP address shows.
              Sent from my crystal box, using my cat's whisker.
              • ryns10
                • May 2012
                need some help on my breambox
                will tis help me reflash my breabox 800 hd se again? and how can i choose the correct image to fiash
                • DBTraitor
                  • Feb 2011
                  • 616
                  these 3 are the latest 800se images posted on download section.
                  Just choose one to flash
                  Digital Kaos - Downloads - BlackHole-1-7-1ra-dm800se-ramiMAHER #ssl84b SIM2
                  Digital Kaos - Downloads - openaaf-1.0-dm800se-2012-04-17-sim2-SSL-84b. by ag
                  Digital Kaos - Downloads - iCVS-release 3.2.2-dm800se-28.03.12-ssl84b-sim210-
                  Flashing guide for 800HD/800SE
                  [ame="http://www.youtube.com/watch?v=7ULZ6OujVco"]how to flash the dreambox dm 800 hd flash the dm 800 hd - YouTube[/ame]
