swiss kable and dm800se sr4 (sunray)
  • changuinas
    • May 2012
    DM800 swiss kable and dm800se sr4 (sunray)
    Hello,
    I'm asking for help for my sunray with 3 tuners recently gained, I can only see 15 channels via a cable Switzerland (Geneva). I tried with several images of the latest generation, with them we can see three tuners in the configuration of tuners. This is the image nemesis combo I currently test and whose tnt sat and found all frequencies and tranpondeurs, but on the cable it is only 15 channels! And the file cables.xml is the same thanI use with another dm800se in another room and he work perfectly..., thank you so have some idea or cable.xml file to test.
  • lolcat011
    • May 2012
    Hi,
    I'm from switzerland too and got the same issue with a DM500.
    Do you found some fix for your problem?
