Streaming to laptop
  • tomhick024
    • 559
    Streaming to laptop
    Hi All,
    I was using version 3 of mFaraj viewer with a while, was messing around the other day with another viewer 'FISCstream' (found on a recent post here)but could not get i to work, so i unstalled it again!
    After that my mfarajdb viewer will not work properly! I also tried version 4 but its still the same, it has full control of my 500, but it on streams video properly for 3-4 seconds and then it hangs up and glitches, sound is fine!!
    Maybe you would have some suggestions i could try?
    What i did notice when i reinstalled that some files were being shared so i kept them and tried-no luck, so reinstalled and overwrote them and turned off file sharing and tried again!
    Still the same results!
    (Not a whizz with software i must admit)
    Whatever!!
  • tomhick024
    • 559
    Thanks to 'mFaraj57' for getting back to me with the fix, working perfectly again!
    Cheers Mate
    Whatever!!
    • sossybaby
      • 90
      just out of interest can this work the other way.
      i mean, can i download a film from the internet and watch it on the tv via the dreambox.
      there is an article in this months whatsat which suggests this is possible.
      cheers.
      • tomhick024
        • 559
        I presume if you have setup Ngrab recording, and if you place movie in the original folder that it records to, and file is in correct format it should work.
        Don't use ngrab myself - must have a go at it!!
        Whatever!!
