help please to ftp the fix please again.
  • rocketman
    • 40
    I am having trying to ftp the fix on my dreambox 500c when I get to the stage of copying the SCCE and Keys over to the dreamboxall goes well but when I unplug the power from the box the changes get undone and I am left with the original SCCEs and KEYs. Hope you can help before I go nuts with this box. Thanks
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Are you sure the files are copying across?
    Try doing a factory reset and try again.
    • rocketman
      • 40
      Thanks devilfish my wifes watching dancing on ice at the moment, do I do a factory reset and that is all, as I,ve said before I am a novice at this and I need it all laid out simply. Thankyou.
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        After you do a factory reset, its as if you've just flashed the image, so you're back to square one with a fresh setup. Copy the key files to /var/keys and roms to /var/scce, then reboot the box and see if the channel clears.
        • rocketman
          • 40
          Thanks devilfish I will get on to that as soon as my wife gives up control of the television.
          • despdan
            • 544
            dont unplug the power goto menu>shutdown>restart box it wont remember if you just unplug the power.
            • rocketman
              • 40
              Hi guys, I,ve tried everthing you have suggested I still feel I am doing something stupid but I,ve changed the image twice downloaded the fix again and tried every combination I can think of but all I get is fta channels. What I have noticed after checking all the guides the ftp the fix for noobs final picture shows scce highlighted and in the lower pane the nagroms, if I replicate that I show an scce folder in the lower and a sub box in the upper pane which then shows the nagroms. Help please.
              • rocketman
                • 40
                Yahoo got the box back working again and I Knew it would be me doing something daft , I was trying to drag the file over as a complete unit and it was going in as a sub-file. When I moved the indivdual files over one at a time success, hope that makes sense. Thanks for the help I always get from the guys on this site and I am now fairly comfortable flashing images ,ftp,ing and the layout of the dreambox thanks only to Digital Kaos and its members.
