hi all i just lost all my channels not sure why was missing a few earlier today but now all gone using blck boxt been problem free till now any advice be appreciated
ireland mmds
dreadfand
have you got the fix on your box m8 or have the keys just been entered? if its the latter you will need to use the stickys to ftp the fix over to your box so as to not have to enter keys every few days.
dreadfand -
Don't know whether you are with Chxxus or NxL mmds, but even if codes rolled, you should still find all chanells but only able to view some, should have RTE1 comming through.
Check all connections to start with or check with subbed box!
Whatever!!Comment
If you can check with subbed box, do, that will verify downconverter and psu working, if you cannot, check that psu to downconverter has not died -if ok, looks like the tuner has bit the bullet!
Whatever!!Comment
Hi darren
It would probably be best to give a complete description of what you have done so far.
It makes it easier to diagnose the fault if you give as much info as possible.
What image did you flash? what other files did you put in. Are you getting the FTA channels?
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the worldComment
hi , im new on this site... like yourself i have just bought a boxt, but cant find the relevent code to put in when im at the nagravision setup point,, im also a techno dunce!!!! which im sure is a huge 'bonus'[???!!!!] to me. ive all the channel info, and am recieving rte1, sky news, how did you fare out when you lost signal? are you still happily viewing?Comment
