Tutorial on how to Telnet & backup flash For DM500 using putty
PD DreamboxToolbox v.9.0-Largest source of Dreambox Satellite Receiver
Note : Box must have connection to internet for it to work
Be sure to have your rs232 null cable to dreamup flash just in case anything goes wrong
Open PD_DreamboxToolbox _V.9.0.0
Open DCC/establish connection
Open Putty telnet
1. Host Name (or IP address) - Fill this box with your box ip
2. Port - Use default 23
3. Connection type - Telnet
4. Click Save
5. Close window on Exit - Only on clean Exit (So u know that if it is successful or not)
6. Click open
7. DM500 Login is - root (small letterword)/ Click Enter
8. Password - dreambox (small letterword)/ Click Enter
Congratulation u have successfull establish connection with your DM500
Next step is how to Flash or backup your box images taken from Mr. Devlish post
Let me explain in detail:
This method will only work with a .img image file. - ( means only img format no other format will work)
Rename the images file that u want to upgrade or change to backup
FTP or send the backup images that u already rename it to your box temp folder using DCC
copy & paste
cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
to the putty program/click Enter/wait till the putty program to auto close
Note : If u get illegal messages or the program do not auto close after 100% not to worry
force close putty program/Point your RCU to box then press any buttons as for me volume up buttons
force reboot box by off the main power wait for about 15sec than on the power back (sometime it just won't work)
If the box just hang won't reboot than the only solution is dreamup, as u can't change from normal to maxvar images vise versa
As for backup images
copy & paste
cat /dev/mtd/3 > /tmp/backup.img
click Enter/wait for the root@DM500 ~ # (in blue colour) means u successful backup the whole images
FTP to your box temp folder using DCC there u can find your backup images/save to your pc/delete the backup images from the temp folder after u save it
My advise is to do the backup method 1st, if u can do this than u can try to flash or upgrade a different images
This is my way of using telnet flash if u guys felt that i miss something or want to add info please do so
We r all here to share knowledge & experience
Open Putty telnet
4. Click Save
6. Click open
copy & paste
copy & paste
thumbs up for the guide onces again!
