DM800hd se not booting
  • belal84
    • Jun 2012
    Hi all, my dm is not booting anymore, i was trying to record on my usb when i see a green screen about dm crash and after that dm is not booting.... i see booting on my screen when it starts then the blue led flash for five seconds then nothing happens.
    i connected to the box and i got the boot output but i don't know the problem, can someone please help?
    BCM74130011
    012
    K1
    K2
    K3
    K4
    K5
    Shmoo Version=3.8
    DDR Freq=0x0000018C
    %00000001%
    RC1=00000006
    WC1=FFFFFFE7
    RC2=00000019
    WC2=FFFFFFEE
    RC3=0000000F
    WC3=FFFFFFE6
    RC4=0000000F
    WC4=00000035
    NWC=0000000D
    RC5=00000006
    WC5=0000000D
    RC6=00000018
    WC6=0000000D
    NRC=0000000F
    RW=00000013
    WW=00000050
    G=00000000 R=0000000F W=0000000D
    BL=00000000
    RC1=00000004
    RC2=00000014
    BL=00000001
    RC1=00000004
    RC2=00000013
    BL=00000002
    RC1=00000002
    RC2=00000012
    BL=00000003
    RC1=00000003
    RC2=00000016
    BL=00000004
    RC1=00000003
    RC2=00000016
    BL=00000005
    RC1=00000005
    RC2=00000018
    BL=00000006
    RC1=00000005
    RC2=00000017
    BL=00000007
    RC1=00000008
    RC2=0000001B
    3
    COPY CODE
    COMPARE CODE
    4567
    (c) 2007,2008 Dream Multimedia GmbH. All rights reserved.
    Dreambox DM800SE
    FIRST STAGE 1.0/400 {BO23456}
    2ND STAGE OK, build #84 (2011-09-01)
    0.000  - BCM board setup
    0.000  - fp init
    0.000  - ca init
    0.438  - load config
    dCA: broken.
    0.464  - config loaded.
     * press [S] to enter setup
    OLED found!
    color oled reset
    lcd: BOOT #84B
    P23 detected!
     - read config file: /boot/secondstage.conf
    detected jffs2 blocksize: 16kb
    ++++++++++++++++++++++++++++++++++++++++++++++++++B++++++++++++
    ++++++++++++++++++++UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
    UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
    dreamupd initialized
    Scanning JFFS2 FS: . done.
    find_inode failed for name=secondstage.conf
    load: Failed to find inode
     - failed to open /boot/secondstage.conf
     - failed to open /cf/autorun.bat
    lcd: /flash/bootlogo.elf
    bootlogo size: 191398
    Supported modes: NTSC !NTSC_J !NTSC_443 !PAL_B !PAL_B1 !PAL_D !PAL_D1 PAL_G !PAL_H !PAL_K !PAL_I !PAL_M !PAL_N !PAL_NC !PAL_60 !SECAM_L !SECAM_B !SECAM_G !SECAM_D !SECAM_K !SECAM_H 1080i !1080p 720p 480p 1080i_50Hz !1080p_50Hz !1250i_50Hz 720p_50Hz 576p_50Hz DVI_640x480p !DVI_640x480p_CVT DVI_800x600p DVI_1024x768p !DVI_1280x720p_50Hz !DVI_1280x720p !DVI_1280x720p_Red !DVI_640x480p_66Hz !DVI_640x480p_70Hz !DVI_640x480p_72Hz !DVI_640x480p_75Hz !DVI_640x480p_85Hz !DVI_1280x720p_70Hz !DVI_1280x720p_72Hz !DVI_1280x720p_75Hz !DVI_1280x720p_85Hz !DVI_1360x768p_60Hz !DVI_1920x1080p_60Hz_Red !Custom0 !Custom1
    best supported mode is 25
    using 1920x1080i (50.00 Hz)
    HDMI
    using colorspace: 1
    create surface 1920 1080
    Using the Small jpeg decoder library, Copyright (c) 2006, Luc Saillard <[email protected]>
    parsing JPEG header..
    Virtual FB Size: 1280x720
    lcd: /flash/vmlinux.gz
    <5>Linux version 2.6.18-7.4-dm800se (newnigma2@vs35) (gcc version 4.4.3 (GCC) ) #1 SMP Sun Dec 11 05:14:53 UTC 2011
    Fetching vars from bootloader... none present, using defaults.
    Detected 256 MB on MEMC0 (strap 0x22bc0010)
    <4>WARNING: read invalid MAC address ff:ff:ff:ff:ff:ff from flash @ 0xbffff824
    Default command line =
    root=/dev/mtdblock3 rootfstype=jffs2 rw console=ttyS0,115200
    1 831ffebc 830299d4
    g_board_RAM_size=256MB
    Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 ebi_war=0 pci=1 smp=1
    CPU revision is: 0002a044
    FPU revision is: 00130001
    Determined physical RAM map:
     memory: 10000000 @ 00000000 (usable)
    ---> memsize from bootloader: 140
    User-defined physical RAM map:
    node [00000000, 08c00000: RAM]
    node [08c00000, 07400000: RSVD]
    <5>Reserving 116 MB upper memory starting at 08c00000
    <7>On node 0 totalpages: 65536
    <7>  DMA zone: 65536 pages, LIFO batch:15
    Built 1 zonelists.  Total pages: 65536
    <5>Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2 rw console=ttyS0,115200
    [4294667.296000] Primary instruction cache 32kB, physically tagged, 2-way, linesize 64 bytes.
    [4294667.296000] Primary data cache 64kB, 4-way, linesize 64 bytes.
    [4294667.296000] Synthesized TLB refill handler (23 instructions).
    [4294667.296000] Synthesized TLB load handler fastpath (37 instructions).
    [4294667.296000] Synthesized TLB store handler fastpath (37 instructions).
    [4294667.296000] Synthesized TLB modify handler fastpath (36 instructions).
    [4294667.296000] PID hash table entries: 2048 (order: 11, 8192 bytes)
    [4294667.296000] Found MIPS counter frequency: 203 Mhz
    [4294667.296000] Using 202.501 MHz high precision timer.
    [4294667.296000] Console: colour dummy device 80x25
    [4294667.303000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    [4294667.303000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    [4294667.316000] Memory: 137088k/262144k available (2810k kernel code, 124824k reserved, 602k data, 140k init, 0k highmem)
    [4294667.338000] Mount-cache hash table entries: 512
    [4294667.339000] Checking for 'wait' instruction...  available.
    [4294667.339000] plat_prepare_cpus: ENABLING 2nd Thread...
    [4294667.340000] TP0: prom_boot_secondary: Kick off 2nd CPU...
    [4294667.342000] CPU revision is: 0002a044
    [4294667.342000] FPU revision is: 00130001
    [4294667.342000] Primary instruction cache 32kB, physically tagged, 2-way, linesize 64 bytes.
    [4294667.342000] Primary data cache 64kB, 4-way, linesize 64 bytes.
    [4294667.342000] Synthesized TLB refill handler (23 instructions).
    [4294667.363000] Brought up 2 CPUs
    [4294667.396000] migration_cost=1000
    [4294667.399000] NET: Registered protocol family 16
    [4294667.400000] registering PCI controller with io_map_base unset
    [4294667.402000] SCSI subsystem initialized
    [4294667.403000] usbcore: registered new driver usbfs
    [4294667.404000] usbcore: registered new driver hub
    [4294667.405000] NET: Registered protocol family 2
    [4294667.418000] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [4294667.419000] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [4294667.420000] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [4294667.421000] TCP: Hash tables configured (established 8192 bind 4096)
    [4294667.422000] TCP reno registered
    [4294667.422000] brcm-pm: disabling power to USB block
    [4294667.423000] brcm-pm: disabling power to ENET block
    [4294667.424000] brcm-pm: disabling power to SATA block
    [4294667.427000] JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
    [4294667.428000] Initializing Cryptographic API
    [4294667.429000] io scheduler noop registered
    [4294667.429000] io scheduler anticipatory registered
    [4294667.430000] io scheduler deadline registered
    [4294667.430000] io scheduler cfq registered (default)
    [4294667.436000] Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
    ?[4294667.437000] serial8250: ttyS0 at MMIO 0x0 (irq = 22) is a 16550A
    [4294667.438000] serial8250: ttyS1 at MMIO 0x0 (irq = 67) is a 16550A
    [4294667.438000] brcm-pm: enabling power to ENET block
    [4294667.439000] Broadcom BCM7413 P21 Ethernet Network Device v2.0 Dec 11 2011 05:14:11
    [4294667.445000] Config Internal PHY Through MDIO: 100 MB Full-Duplex (auto-neg)
    [4294669.082000] brcm-pm: enabling power to SATA block
    [4294669.098000] ata1: SATA max UDMA/133 cmd 0xB0510100 ctl 0xB0510120 bmdma 0xB0510130 irq 42
    [4294669.099000] ata2: SATA max UDMA/133 cmd 0xB0510000 ctl 0xB0510020 bmdma 0xB0510030 irq 42
    [4294669.100000] scsi0 : sata_svw
    [4294669.403000] ata1: SATA link down (SStatus 4 SControl 300)
    [4294669.435000] ATA: abnormal status 0x7F on port 0xb051011c
    [4294669.435000] scsi1 : sata_svw
    [4294669.739000] ata2: SATA link down (SStatus 4 SControl 300)
    [4294669.771000] ATA: abnormal status 0x7F on port 0xb051001c
    [4294669.771000] Broadcom STB NAND controller (BrcmNand Controller)
    [4294669.772000] NAND_CS_NAND_XOR=00000000
    [4294669.773000] brcmnand_probe: CS0: dev_id=ad76ad76
    [4294669.773000] After: NandSelect=40000002, nandConfig=04042300
    [4294669.774000] NAND Config: Reg=04042300, chipSize=64 MB, blockSize=16K, erase_shift=e
    [4294669.775000] busWidth=1, pageSize=512B, page_shift=9, page_mask=000001ff
    [4294669.776000] timing1 not adjusted: 5363444f
    [4294669.776000] timing2 not adjusted: 00000fc6
    [4294669.777000] BrcmNAND mfg ad 76 Hynix HY27US08121A (dream) 64MB
    [4294669.778000]
    [4294669.778000] Found NAND: ACC=f7ff1010, cfg=04042300, flashId=ad76ad76, tim1=5363444f, tim2=00000fc6
    [4294669.779000] BrcmNAND version = 0x0302 64MB @00000000
    [4294669.780000] B4: NandSelect=40000002, nandConfig=04042300, chipSelect=-1
    [4294669.780000] brcmnand_probe: CS-1: dev_id=ad76ad76
    [4294669.781000] After: NandSelect=40000002, nandConfig=04042300
    [4294669.782000] Found NAND chip on Chip Select -1, chipSize=64MB, usable size=64MB, base=0x
    [4294669.783000] brcmnand_scan: B4 nand_select = 40000002
    [4294669.783000] brcmnand_scan: After nand_select = 40000002
    [4294669.784000] page_shift=9, bbt_erase_shift=14, chip_shift=26, phys_erase_shift=14
    [4294669.785000] Brcm NAND controller version = 3.2 NAND flash size 64MB @1c000000
    [4294669.786000] mtd->oobsize=16, mtd->eccOobSize=16
    [4294669.786000] brcmnand_scan:  mtd->oobsize=16
    [4294669.787000] brcmnand_scan: oobavail=12, eccsize=512, writesize=512
    [4294669.788000] brcmnand_scan, eccsize=512, writesize=512, eccsteps=1, ecclevel=15, eccbytes=3
    [4294669.789000] brcmnand_default_bbt: bbt_td = bbt_main_descr
    [4294669.791000] brcmnandCET: Status -> Deferred
    [4294669.792000]        numchips=1, size=4000000
    [4294669.792000] Creating 4 MTD partitions on "bcm7xxx-nand.0":
    [4294669.793000] 0x0000000000000000-0x0000000004000000 : "complete"
    [4294669.797000] 0x0000000000000000-0x0000000000040000 : "loader"
    [4294669.798000] 0x0000000000040000-0x0000000000400000 : "boot partition"
    [4294669.799000] 0x0000000000400000-0x0000000004000000 : "root partition"
    [4294669.803000] ehci_hcd_brcm_init: Initializing 2 EHCI controller(s)
    [4294669.804000] brcm-pm: enabling power to USB block
    [4294669.805000] 10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-0)
    [4294669.806000] drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
    [4294669.807000]  - USB h/w setup mode <B>
    [4294669.807000]  - USB power enable set for active LOW mode
    [4294669.808000] brcm-ehci brcm-ehci.0: BRCM EHCI
    [4294669.808000] brcm-ehci brcm-ehci.0: new USB bus registered, assigned bus number 1
    [4294669.809000] brcm-ehci brcm-ehci.0: irq 62, io mem 0x10480300
    [4294669.810000] brcm-ehci brcm-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
    [4294669.811000] usb usb1: configuration #1 chosen from 1 choice
    [4294669.812000] hub 1-0:1.0: USB hub found
    [4294669.813000] hub 1-0:1.0: 2 ports detected
    [4294669.914000] 10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-1)
    [4294669.915000] drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
    [4294669.916000] brcm-ehci-1 brcm-ehci-1.1: BRCM EHCI
    [4294669.916000] brcm-ehci-1 brcm-ehci-1.1: new USB bus registered, assigned bus number 2
    [4294669.917000] brcm-ehci-1 brcm-ehci-1.1: irq 57, io mem 0x10480500
    [4294669.918000] brcm-ehci-1 brcm-ehci-1.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
    [4294669.919000] usb usb2: configuration #1 chosen from 1 choice
    [4294669.920000] hub 2-0:1.0: USB hub found
    [4294669.921000] hub 2-0:1.0: 2 ports detected
    [4294670.022000] ohci_hcd_brcm_init: Initializing 2 OHCI controller(s)
    [4294670.023000] 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-0)
    [4294670.024000] drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
    [4294670.024000]  - Resetting at b0480408
    [4294670.025000] <-- brcm_start_hc
    [4294670.025000] brcm-ohci-0 brcm-ohci-0.0: BRCM OHCI
    [4294670.026000] brcm-ohci-0 brcm-ohci-0.0: new USB bus registered, assigned bus number 3
    [4294670.027000] brcm-ohci-0 brcm-ohci-0.0: irq 63, io mem 0x10480400
    [4294670.083000] usb usb3: configuration #1 chosen from 1 choice
    [4294670.084000] hub 3-0:1.0: USB hub found
    [4294670.084000] hub 3-0:1.0: 2 ports detected
    [4294670.186000] 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-1)
    [4294670.187000] drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
    [4294670.188000]  - Resetting at b0480608
    [4294670.188000] <-- brcm_start_hc
    [4294670.189000] brcm-ohci-1 brcm-ohci-1.1: BRCM OHCI
    [4294670.189000] brcm-ohci-1 brcm-ohci-1.1: new USB bus registered, assigned bus number 4
    [4294670.190000] brcm-ohci-1 brcm-ohci-1.1: irq 64, io mem 0x10480600
    [4294670.246000] usb usb4: configuration #1 chosen from 1 choice
    [4294670.247000] hub 4-0:1.0: USB hub found
    [4294670.247000] hub 4-0:1.0: 2 ports detected
    [4294670.349000] Initializing USB Mass Storage driver...
    [4294670.349000] usbcore: registered new driver usb-storage
    [4294670.350000] USB Mass Storage support registered.
    [4294670.351000] i2c /dev entries driver
    [4294670.351000] Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).
    [4294670.352000] ALSA device list:
    [4294670.353000]   No soundcards found.
    [4294670.353000] TCP bic registered
    [4294670.354000] NET: Registered protocol family 1
    [4294670.354000] NET: Registered protocol family 17
    [4294678.037000] Empty flash at 0x0348a7b4 ends at 0x0348a800
    [4294678.952000] VFS: Mounted root (jffs2 filesystem).
    [4294678.953000] Freeing unused kernel memory: 140k freed
    mount: no /proc/mounts
    udevd[63]: lookup_group: specified group 'pcscd' unknown
    find: /dev/sd??: No such file or directory
    [4294682.499000] input: dreambox remote control (native) as /class/input/input0
    [4294682.501000] input: dreambox advanced remote control (native) as /class/input/input1
    [4294682.566000] input: dreambox ir keyboard as /class/input/input2
    [4294682.567000] input: dreambox ir mouse as /class/input/input3
    udevd-event[322]: node_symlink: device node '/dev/dbox/lcd0' already exists, link to '/dev/dbox/oled0' will not overwrite it
    [4294683.662000] enter base init, xvd 20100413, vdc 20100413, rap 20100719, xpt 20100825
    [4294684.138000] 16:842015000 SMCA: controller reset timed out
    [4294684.148000] 16:852012000 SMCB: controller reset timed out
    [4294684.153000] register adapter
    [4294684.154000] register adapter
    [4294684.155000] register adapter
    [4294684.156000] register adapter
    [4294684.158000] FP Version 3
    [4294684.161000] input: dreambox front panel as /class/input/input4
    [4294684.165000] HDMI: device attached
    [4294684.168000] keys 81
    [4294684.206000] set sb to 3(2)
    [4294684.207000] set fb to 2(-1)
    [4294684.207000] set input to 0
    [4294684.212000] bcm_video_analog_port_setup (fmt=7)
    [4294684.213000] SET FORMAT: display[1], format=7
    [4294684.214000] display 0 uses vbi path 1
    [4294684.214000] display 1 uses vbi path 0
    [4294684.215000] HDMI: hotplug handler!
    [4294684.244000] using 50.00Hz as MonitorRefreshRate
    [4294684.244000] SET FORMAT: display[0], format=37
    [4294684.245000] HDMI detected
    [4294684.245000] HDMI mode
    [4294684.246000] use EDID to detect colorspace
    [4294684.246000] using colorspace: 1
    [4294684.320000] set fb to 2(0)
    [4294684.320000] bcm_video_analog_port_setup (fmt=7)
    [4294684.321000] SET FORMAT: display[1], format=7
    [4294684.328000] disable wss on display 0
    [4294684.328000] disable wss on display 1
    [4294684.329000] bcmfb: creating surface with pixel format 0x07e48888 (BPXL_eA8_R8_G8_B8)
    udevd-event[390]: node_symlink: rename(/dev/fb.udev-tmp, /dev/fb) failed: Is a directory
    [4294684.462000] enable mad
    [4294684.508000] VIDEO0: set fallback framerate to 60000
    [4294684.509000] VIDEO0: set progressive override mode to 1
    [4294684.509000] VIDEO0: set streamtype!
    [4294684.510000] set MPEG2
    [4294684.510000] sw rave disabled!
    [4294684.514000] sync is off so we enable it
    [4294684.514000] playback!
    [4294684.515000] total video delay: 0 (0 ms)
    [4294684.518000] VIDEO0: start decode
    [4294684.519000] flush video decoder
    [4294684.519000] VIDEO0 got pts failed !!!! (ret 0)
    [4294684.972000] set ac3 to downmix
    [4294684.973000] set aac to downmix
    [4294685.008000] VIDEO0: first pts 0x0
    [4294685.025000] init ALSA!
    [4294685.028000] DVB: registering new adapter (BCM7405)
    [4294685.042000] autodetecting NIMs...
    [4294685.044000] ret: 2, feid: 13
    [4294685.044000] Found: Slot A, ID: 13 (by CA)
    [4294685.045000] Initializing adapter 0 (BCM4505-DVB-S2)
    [4294685.105000] bcm4506: found 4505, revision 0(b0)
    [4294685.106000] bcm4506: bcm_initAP
    [4294685.114000] bcm4506: upload & start firmware
    [4294685.158000] enable tsm0
    [4294687.053000] bcm4506: bcm4506: ap not running - start now
    [4294687.141000] bcm4506: uCode 0x5a
    [4294687.158000] bcm4506: no bcm3445 detected
    [4294687.171000] i2c_enable_adc failed! -145
    [4294687.171000] DVB: registering adapter 0 frontend 0 (bcm4506)...
    [4294687.199000] registered vtuner vtuner0, minor 58
    [4294687.200000] registered vtuner vtuner1, minor 57
    [4294688.374000] VIDEO0: stop decode
    [4294688.374000] no decoder left in sync handling so disable xpt_sync
    [4294688.387000] using 50.00Hz as MonitorRefreshRate
    [4294688.486000] SET FORMAT: display[0], format=27
    [4294688.487000] HDMI detected
    [4294688.488000] HDMI mode
    [4294688.488000] use EDID to detect colorspace
    [4294688.488000] using colorspace: 1
    [4294688.568000] bcm_video_analog_port_setup (fmt=7)
    [4294688.687000] SET FORMAT: display[1], format=7
    [4294688.807000] set current avs auto aspect to 16:9
    [4294688.807000] disable wss on display 0
    [4294688.808000] disable wss on display 1
    [4294688.808000] set sb to 3(1)
    [4294688.936000] JFFS2 notice: (1) read_dnode: node CRC failed on dnode at 0x348a5c8: read 0xffffffff, calculated 0xaacdefeb
  • edlimym
    • Feb 2012
    • 29
    do you have a backup copy of your current image? re-flash the box with it if you have.
    • mtv1
      The Stig PT
      • 4413
      go the old way m8 dreamup with mini usb cable seen a tut brb try a new image
      • mtv1
        The Stig PT
        • 4413
        http://www.digital-kaos.co.uk/forums...1/#post1335807 found it
        • belal84
          • Jun 2012
          Originally posted by mtv1
          thanks for the support, do you know which image i should use? also how to packup the Cccam.cfg file before re-flash?
          • mtv1
            The Stig PT
            • 4413
            lots of images out there pli dreamelite etc. just make shure you get the right one for you box clonesafe one backing up cccam might be a problem do you know the gifts contents if not download tuxbox from downloads on the box and find it that way var/etc/cccam.cfg pm me if you need further help
