picon path setting for dm800hd se
  • Moksan22
    • Jul 2012
    • 19
    In which folder should I ftp the picon images?for dm800hd SE? What is the path setting?in dreamedit my profile set as media/hdd/picons but still no changes when I ftp the files.is this the correct path setting or I should make changes to the dreambox path?
  • alienated
    • Mar 2012
    • 29
    Check your system settings!
    Change the path in DBedit to match your system picon path.
    • Moksan22
      • Jul 2012
      • 19
      When I go to the system path settings there's only 2 option to choose 1)flAsh memory or 2)hard disk.which one should I choose and Watts the Picon path.
      • ypvs125
        • Dec 2010
        • 506
        Some image have different path for picon folder but mostly in usr/share/enigma2 so if u can tell us what image u r using, it will be easier for us to advise.
        • Moksan22
          • Jul 2012
          • 19
          I'm using the dream elite 3.0 dm800se 010r4-e3-SSL-84b
          I tried FTP to usr/share/enigma2/picon but still unble to get the new picons shown in dreambox channel.but the new picons was successfully FTP to this folder.
          • Moksan22
            • Jul 2012
            • 19
            Finally got the new picons.the path is still the same usr/share/enigma2/picon.somehow when I FTP using DCC the new picons was not added to the dreambox..so I individually transferred one at a time and it worked.Thanks all for contributing ur suggestions.this forum rocks.
