Cannot find ip address for dm500c
  • ripmaster
    • 130
    Hi guys hope you can help me bought a dm500c but it has come with no remote.I have flashed the dk1.1 image onto it and get the screen when i turn it on and the tv setup wizard appears.But with having no remote untill the new one arrives is all i can do.However when i try to find its ip address after connecting to my router it cannot find it.I have tried to find it through dreambox control center and all that comes up is the router address and by going into the router and looking for attached devices.any help much appreciated
  • thered
    • Aug 2008
    • 4915
    think you will need a remote m8 can you not borrow 1 from sum 1
    • ripmaster
      • 130
      No m8 if i get a crossover cable will it be easier to ftp the keys into the box than trying to connect via modem.Ordered a remote from skywonder hope it comes b4 weekend want to watch fight
      Last edited by ripmaster; 10 March, 2009, 20:46. Reason: spelling mistakes words missing
      • ripmaster
        • 130
        Is it easier to use a crossover cable to connect to your dreambox via pc
        • ripmaster
          • 130
          Do you have to set the box up first via the remote b4 you can connect via ftp or if you connect via crossover cable do you not need ftp.Please help me
          • aftermath
            • 4345
            yes, you need to go into settings/advanced/network settings and change the IP address to suit your router, preferably within 10 of your Router Ip address, or if its a direct connection , within 10 of your PC IP address.
            • s.ahmed
              • 44
              If your using a router, connect to it directly
              (open internet browser, for netgear the address is 192.168.1.1 and belkin its 192.168.2.1).
              Type your routers address in the browser.
              Once your into the router setup page, see if you have an option that says attached devices, click on it and it should have your ip addresses for your attached devices.
              Hope this helps.
              • ripmaster
                • 130
                If i use a crossover cable directly to pc do i still need the ip address or does this do away with that cheers
                • aftermath
                  • 4345
                  still need IP address, change it to 1 above your PC network card, os change PC network card settings to use a set IP, to match your dm500.
                  • ripmaster
                    • 130
                    So i wont be able to put the keys in untill i have the remote gone into the router settings and attached devices it does not pick it up
                    • ripmaster
                      • 130
                      nope router not picking up the dreambox as attached
                      • ripmaster
                        • 130
                        Ooops sorted flashed the enigma image and now connects
                        • ripmaster
                          • 130
                          Do i not do a flash erase when putting the dk 1.1 image on via dreamup
                          • thered
                            • Aug 2008
                            • 4915
                            should be ok as it is but if you want to be sure go for it
                            • ripmaster
                              • 130
                              Hi guys remote has come and i have connected my box to my broadband line and done an automatic scan it does not find any channels i do not have the aerial connected.All help appreciated
