help please can get 90% of channels but sly sports 2 i cant detect? works ok on eurovox?
cant get sly sports 2
Bet the BER is through the roof like Devilfish says check your cables if o.k I have used one of the variable cable boosters - had the same problem.
The ones I have found are great they are all metal and cable ones not TV and have a variable twin output with screw threads.
On eBay if you get them on your opening bid they work out less than ?8, all you have to do is swap the 2 pin plug for a 3 pin UK - don't forget to swap the fuse for a low one i.e. no more than 3 amp :-)
http://cgi.ebay.co.uk/Household-Cabl...QQcmdZViewItemLast edited by bbhs; 1 May, 2008, 07:24.Comment
