Hi guys, i bought a dreambox 500c and used in BB and there is no problem, but when i moved it to Holland village, it can received any signal..any advise?
Dreambox 500c can use in BB but not in Hollandv
Tags: None
Some members have this same problem due to signal not activated ( never subscribed to SH b4 ).
If not, perhaps other seniors can advise u
Remember: Do not anyhow reset your box unless u have fully backup your box.Comment
Last edited by uu161; 21 July, 2012, 10:32.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
well i stay in 18D, flat not landed property, i check the SH with postal code, it is active, but i dont know why it can use in BB but not in HollandV...Comment
in BB work does mean it will work anywhere depend on ur luck.
do u have a SH stb or cable BB to try out?
if not find a friend with SH stb try your DM at his place to see it work?
if do work then too bad for you
i guess u know what to do
Always scan for *Hub test pattern before engaging in a STB purchase. In newer estates, the default connection is to the fishbone antenna.
If your TV can receive TV3 or SCTV (Indonesia), ur TV antenna is hooked up to a fishbone antenna, definitely won't be able to receive the CATV signals.
The only solution is to subscribe SHTV or Maxonline.
You need the coaxial cabling from *Hub to work.Comment
