Singp*re StarH*b
  • yns88
    • Apr 2009
    • 4
    #16
    Guys from SG, we should group together to brainstorm this.
    • Berg82
      • Apr 2009
      • 6
      #17
      Hmmm. Where do I buy this from? Does the re roll happen very often? for Everyone or random house?
      • despdan
        • 544
        #18
        Lads if you want to keep your boxes working do your-selfs a favour & delete any mention of Star??? & singapo?? from the posts here.
        I will help but i need you to help me.
        • YorYor
          • Apr 2009
          • 7
          #19
          Edited accordingly.
          I've tried using the new .bin files from the auto-update archive as listed in the sticky, and also tried switching to evocamd but still no go.
          Hope despdan can give us a few hints on how to get around this.
          • Berg82
            • Apr 2009
            • 6
            #20
            Do agree with this. Should we continue? or ? First I need to get the set first~
            • despdan
              • 544
              #21
              Originally posted by YorYor
              Edited accordingly.
              One Question Have you got your boxes setup with keys roms & cams? you need to have this done first. btw it would be nice if you have mgcamd & evocamd installed it will help me help you.
              • Berg82
                • Apr 2009
                • 6
                #22
                Other than the DM500C, do I still need Dreambox 500 Tuner? or just the set will do?
                • YorYor
                  • Apr 2009
                  • 7
                  #23
                  Yup, but only the roms that came by default with the box (as listed in my previous post).
                  Keys
                  -rwxr-xr-x 1 root root 4140 Aug 21 2008 AutoRoll.Key
                  -rwxr-xr-x 1 root root 80 Jan 1 1970 SoftCam.Key
                  -rw-r--r-- 1 root root 0 Jan 1 1970 irdeto
                  -rw-r--r-- 1 root root 3660 Jan 1 1970 mg_cfg
                  I've just removed evocamd cause of the size, but no problems, I can easily install it again.
                  Thanks despdan, appreciate your help.
                  • Berg82
                    • Apr 2009
                    • 6
                    #24
                    Can the power adapter be use in the mentioned country or do I need to get a transfomer?
                    • soros
                      • Mar 2009
                      • 13
                      #25
                      to start, you will need the dm500c and a null modem cable... the power cable can be used... but the plug is china plug so you will need an adapter to plug in.. you dont need a transformer
                      • Berg82
                        • Apr 2009
                        • 6
                        #26
                        Great! Buying 1 to test it out!
                        • chantelteo
                          • Apr 2009
                          #27
                          How do i check the above? I was able to watch all channels till the reset by S******. I presume all should be in.
                          • despdan
                            • 544
                            #28
                            @soros
                            did that autoroll/autoupdate work?
                            • soros
                              • Mar 2009
                              • 13
                              #29
                              @soros
                              i just checked and saw your email.. i will go try it out now.. give me 5 min and i will update you...
                              keys:
                              Scce:
                              • YorYor
                                • Apr 2009
                                • 7
                                #30
                                Thanks despdan, will give it a shot once my little boy has finished watching "In The Night Garden". ;p
                                Have already edit the keys and rebooted the box... just need to switch over to see if it works.
                                Update: Still black screen... do I have to rescan? Cause whenever I do automatic scan, it never finds anything...
