Tune Fail - Singapore - DM800C
  • marcel500
    • Jul 2012
    • 8
    Hey just setup my DM800se with a new cable tuner. Unfortunately except 2-3 channels nothings works - always tune fails. The only channels which are ok (not perfect) is BBC and History channel. Not even the starhub intro channel is working.
    I changed cable etc. already any ideas what I can do?
    I am using existing boquets, should I do another manuel scan? Doesnt matter, right?
    Help would be awesome.
    Signal is around SNR 65% or DB 25 DB
  • Jackaligga
    • Jul 2012
    • 20
    Does FTA channels work?
    • marcel500
      • Jul 2012
      • 8
      U mean channel 100? No
      • Jackaligga
        • Jul 2012
        • 20
        When you press info, does it show any info on the channels?
        • marcel500
          • Jul 2012
          • 8
          For mostly all channels it does show info.
          • Jackaligga
            • Jul 2012
            • 20
            It seems that your signals are really weak at 65% and since u can get infos on the channels means that there is nothing wrong with your bouquet service. If u check your BER, it shows to be about 1000+ or more? If changing the cables doesn't help it could be your dreambox's tuner is faulty,or otherwise, get a signal booster.
            • marcel500
              • Jul 2012
              • 8
              It seems that your signals are really weak at 65% and since u can get infos on the channels means that there is nothing wrong with the services. If u check your BER, it shows to be about 1000+ or more? If changing the cables doesn't help it could be your dreambox's tuner is faulty,or otherwise, get a signal booster.
              BER is about: for some channels 0 for other more than 25000
              1. Where can I buy good new tuner? I have original DM800se box.
              2. Where can I buy signal booster? Which brand?
              Thx
              • Jackaligga
                • Jul 2012
                • 20
                Thx
                I'm afraid I'm not very sure about that, I'm just a newbie like u too haha. But u can check about in s1m lim square, they pretty much have most of the stuffs.
                • marcel500
                  • Jul 2012
                  • 8
                  Thanks anyway.
                  Maybe somebody else has an idea?
                  • uu161
                    • May 2012
                    • 372
                    Thx
                    1) i don't think u need to change tuner since yours are original DM should be better then clone.
                    2) can be found at Sim Lim Tower basement. check with the shop how to use it.
                    normally booster are use in main point then output splitter to rest of the point.
                    unless the booster u bought with 4 output then different story
                    just wonder would take pics of the 800se tuner output input?
                    if you like the post use the Like button located bottom right corner of each post
                    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                    • marcel500
                      • Jul 2012
                      • 8
                      ok thanks
                      1. Actually its not the original one bought it only on amazon.de
                      2. I am new in my apartment, do u mean as main point the one next to my TV our is there another one somewhere in my apartment
                      • uu161
                        • May 2012
                        • 372
                        ok thanks
                        for apartment am not sure
                        for HD* got some way to do it even new flat
                        example for new HD* out side of the flat sh cable box the main are there inside there is splitter to house cable point ( living room,room1,room2 etc)
                        • marcel500
                          • Jul 2012
                          • 8
                          example for new HD* out side of the flat sh cable box the main are there inside there is a splitter to house cable point ( living room,room1,room2 etc)
                          So I need to check outside my flat? Its probably on the same level ,right?
                          Is this what Starhub would do?
                          • uu161
                            • May 2012
                            • 372
                            find out urself
                            take ur own risk i didn't teach you
                            before you do all this if u want know isit tuner go ur friends place and try see any problem
                            • marcel500
                              • Jul 2012
                              • 8
                              find out urself
                              Funny enought I just found an opennet box in my apartment... isnt that the fibre cable company?
