E2 SGSH online bouquets updater plugin for sg
  • DBTraitor
    • Feb 2011
    • 616
    #406
    you have to try update again. Sometime it doesnt work on the first try.
    alternatively, you can use the traditional method dreamboxedit to sent files over to the box
    If your box screw up and doesnt know how to resolve, always have a standby backup image to prepare for a reflash.
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • jatrophaseed
      • May 2010
      • 589
      #407
      Haha... screwed up my bouquets many times via online, I think Bros must learn manual scan and update new chn via DreamEdit. That way can stop update bouquet from now.
      • uu161
        • May 2012
        • 372
        #408
        too bad server are back online
        if you like the post use the Like button located bottom right corner of each post
        if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
        • beckz
          • Jun 2013
          • 9
          #409
          I just screwed mine few days ago!
          • madjack
            • Apr 2012
            • 28
            #410
            Luckily I did a back up n ftp the bouquets back n evyting was solved. Free time use db edit to update, busy time used online plug in.. Thanks all the master for the hard work they put in.
            • uu161
              • May 2012
              • 372
              #411
              last week did notice server not stable when i'm doing some edit here and there
              from sunday onwards till yesterday
              anyway i hope its down
              because updated plugin are done since yesterday -.-''
              wait for next time then use liao
              total got 3 server as for now
              1 using now & 2 backup server for standy.
              if u guys found any problem do feedback here i wil try to fix up if i can
              found duplicate channel issue after testin newer image
              • uu161
                • May 2012
                • 372
                #412
                i wish to screwed up all those who are using
                which are not user of digital-kaos
                • pikapika
                  • May 2010
                  • 8
                  #413
                  may i know if this is working, i hook up to st fibre and try numerous times without sucess
                  • uu161
                    • May 2012
                    • 372
                    #414
                    tested 5min ago by sunhine network working not sure others isp
                    • jatrophaseed
                      • May 2010
                      • 589
                      #415
                      all working, not fatpipe.
                      Sent from my GT-I9100 using Tapatalk 2
                      • xstonecold
                        • May 2013
                        #416
                        Dear Seniors , accident press update plungin without internet connection......all screwed up, time go back 2000 all bouquet gone, left open pli screen , wat should I proceed ...my seller gave me this
                        DM800se-OpnPLi-sim2-SSL84B to update channels
                        can I use SG-Open Pli-dm800se-SSL-84b or sg800se-cnigma-ss-84l or just update using dbedit . oh should I connect internet and update plugin again.....TIA
                        • uu161
                          • May 2012
                          • 372
                          #417
                          simple plug in lan ( internet connection) and press update and issue fixed
                          or u can use manual to update bouquet
                          Hints: soon plugin will change new DNs
                          • thyewah
                            • Oct 2012
                            • 11
                            #418
                            New StarHub channels from 19 July, 9am
                            Crime & Investigation Network HD (Ch 463)
                            The Biography Channel HD (Ch 464)
                            WarnerTV HD (Ch 562)
                            BBC World News HD (Ch 755)
                            CNN HD (Ch 760)
                            • jatrophaseed
                              • May 2010
                              • 589
                              #419
                              [QUOTE=thyewah;2032644]New StarHub channels from 19 July, 9am
                              Freq: 163500KHz, Q256, Sym: 6090
                              Crime & Investigation Network HD (Ch 463) V2050 A2051
                              The Biography Channel HD (Ch 464) V2040 A2041
                              WarnerTV HD (Ch 562) V2060 A2061
                              Freq: 156500KHz, Q256, Sym: 6090
                              BBC World News HD (Ch 755) V2020 A2021
                              CNN HD (Ch 760) V2030 A2031
                              Thanks to ThyeWah.
                              Bros, start prepare for Freq: 170500KHz, Q256 and Sym6090 ( abt 8 chn)
                              I highlited, PM asking freq????? Cant see????
                              Oh, DreamBox 500 or SD boxes, pls dont waste your time scanning.
                              • ultrakiasu
                                • 128
                                #420
                                I hope you are not implying that there won't be any more new SD (non-HD) channels...
