anyone got link for the sgsh online updater version 0.3.4?
E2 SGSH online bouquets updater plugin for sg
if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
online update everything fixed check it out yourself
SD BPL channel removed
pls take note online update only work with plugin ver 0.3.4 only
all BPL channels are using official feq & enjoyLast edited by uu161; 6 August, 2013, 17:17.if you like the post use the Like button located bottom right corner of each post
Link for dm800 image with updated channels and BPL. Added cccam 2.21 inside image without config file.
Last edited by Alx75; 6 August, 2013, 15:07.Forum is care n share, read n learn, receive n contributeComment
May I check if channel 232 and 232 are still on freq 150?
Did a scan but no channels found... anyone can verify?
Channel 226-231 found, but same as some bros out there with low signal for 226,227,228.
Channel 229,230,231 perfect.
Thanks masters for the frequencies!Comment
yes no change for 231 &232
226 to 228 signal are most weak atmif you like the post use the Like button located bottom right corner of each post
