How to get Coloured OLED display??
  • reddy
    • 37
    Anyone can advice me how to do it on 800 SE?.
    Tried many ways to get it on the picons displayed on OLED.
    Have been reading and trying to get it setup.. but just couldnt get it?. Read it can use the normal picons in Bouquets, so i FTP it to share/engima 2 / Picons. Is that the way to do it??.
    Appreciate any advice.
  • ypvs125
    • Dec 2010
    • 506
    Originally posted by reddy
    Different image has different way to get the oled picon working. Which image r u using?
    • reddy
      • 37
      thks for the prompt reply bro,
      I'm using Cnigma Open PLI 2.1 ssl84 image. for SG use.
      Thanks in advance for your help.
      • ypvs125
        • Dec 2010
        • 506
        Have a look here. Backup yr original skin_display96.xml in case u want to revert back to original.
        Digital Kaos - Downloads - Oled picon display for latest 800se Cnigma-OpenPl
        • reddy
          • 37
          Cool!!. Dude. It worked.
          Was trying to get this done along time.
          Thanks.
          • ckhub15
            • Jul 2012
            • 18
            Hi, I am using the same image and it worked. But I realised it has screw up the epg, all the tv program name disappeared but the channel name is still there. I have revert the xml and the epg is normal again.
            • uu161
              • May 2012
              • 372
              hi bro what do u mean epg screw up?
              i double check find nothing wrong it was same as original epg function maybe take pics and tell us more
              if you like the post use the Like button located bottom right corner of each post
              if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
              • DBTraitor
                • Feb 2011
                • 616
                probably a different image used
                A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                • ckhub15
                  • Jul 2012
                  • 18
                  Hi, I am using this image Cnigma-OpenPli 2.1-dm800se-ssl84b.nfi.
                  The OLED display worked perfectly, but when I viewed the epg. This is what I see for example, all the movie name disappear.
                  Before updating
                  HBO - The Avengers
                  Starmovies - Arthur
                  After updating
                  HBO
                  Starmovies
                  • uu161
                    • May 2012
                    • 372
                    Before updating
                    HBO - The Avengers
                    Starmovies - Arthur
                    After updating
                    HBO
                    Starmovies
                    i think bro take some pics will tell us more and better understanding
                    if u are saying on the Oled display EGP itself was same as original file i wouldn't see any problem
                    if is dreambox Epg itself also found no fault( tv screen )
                    am wondering are u talking about press bouquet list button?
                    • ckhub15
                      • Jul 2012
                      • 18
                      if u are saying on the Oled display EGP itself was same as original i wouldn't see any problem
                      if talking about the dreambox Epg itself also found no fault( tv screen )
                      Hi, I am referring to pressing the up or down arrow. All the channel list and the current program that is showing will appear (TV Screen). Will try to take some pix later.
                      • uu161
                        • May 2012
                        • 372
                        ha bouquet list
                        ok wait for ur pics
                        • ckhub15
                          • Jul 2012
                          • 18
                          Bro, I have tried to view the bouquet list now and all the movie name that is showing currently has disappear . It seems that this has nothing to do with the skin_display96.xml
                          • uu161
                            • May 2012
                            • 372
                            yup
                            my side show no issue at all
                            faster way a reflash should help.
                            but remember to backup magic file
                            • amazis
                              • Dec 2014
                              • 6
                              I HAVE OPENPLI4 DOES IT WORK FOR ME
