virgin smartcard question?
  • lee1212
    • 58
    hi, guys
    if i put my virgin media smartcard in my dreambox dm500c what will it do?
  • despdan
    • 544
    Originally posted by lee1212
    hi, guys
    Nothing you will have to install newcamd & newcamd.config to get it working also you need your boxkey number.
    • lee1212
      • 58
      so once ive done all this what will the card actually do?
      • dreadfand
        you'll get all the channels that are subscribed to on your package i would assume.
        • Krypton
          • 694
          but if you've got 500c, youve got all the channels, ptobably more than is on your viewing card. question is why whould you?
          Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
          Chuck Norris has two speeds: Walk and Kill
          There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
          Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
          Chuck Norris does not sleep: He waits
          • lee1212
            • 58
            well i currently dont have
            sky 1
            nick
            and probably a few more missing.
            • dreadfand
              probably a signal issue have you tried manually adding the channels via the frequency's and transponders? ... older dreambox's have problems picking up sky one and a few other channels because the tuner isn't that good on lower ranges but a signal booster fixes the issue.
              dreadfand
              • Scarface
                • 92
                hi, guys
                You don't need to put your card in a 500c, if you put all the roms and keys in and scan you will pick up all the channels.
                • dreadfand
                  did you even read the previous posts?
                  • Scarface
                    • 92
                    Yes, hence why I put "you don't need to put the card in". I didn't say he couldn't, just said he didn't need to.
                    • red devil
                      • Oct 2008
                      • 690
                      hi, guys
                      first u will have to unloop ur card with an unlooper (this unlocks the card) then using a phoenix programmer and nagraedit read ur card, edit it to give u all channels and edit ur newcamd config file(as said by despdan) with ur boxkey...still want to do it now ? a lot of work if ur a noob so id say just do wat everyone else is doing flash an image and ftp the so called magic files to get u free tv......btw if thats a subbed card u have, messin with it is a big no no in this game, not recommended
                      • lee1212
                        • 58
                        ok thankyou all for your help!!!
                        • Donnie Darko
                          • 442
                          If you can get an open card,and a valid boxkey from your area,job done.
                          Dont forget traders cloned muliple boxes with the same boxkey in areas.
                          In theory its possible this way for the db.
                          Checkout the RED stickies massive amount of info and effort been put into them.
                          • despdan
                            • 544
                            Just to let you know myself & I think red devil have cards working in dreambox. Never managed to copy over to funcard would only work for 30-60 seconds then stop restart box again 30-60 seconds????
                            • Donnie Darko
                              • 442
                              Yeah seen your thread at the other place,open moscs can be had for ?7 tops.
                              BK and away you go.
