Just a little help please?
  • jonnyair
    • Mar 2009
    • 4
    Only my 2nd post and i'm afraid i've already got a question. Just had openmedia box delivered and wanna start fiddling! I havnt got an rs-232, well i have sort of, but it is rs232 to ps2 (found it in a box of random cables i've got horded) with only 5 pins connected on the ps2 side. Does that sound like it'll do the job, just like the rs232 to usb does, or d'ya reckon i'm gonna have to take a trip to the cable guy? No way i'm paying ?10 at maplins but can't bear waiting for 1 to be delivered.
  • jckw
    • 760
    no u need r232 cable m8 wont work with other one
    we are all learning each day
    • jonnyair
      • Mar 2009
      • 4
      Cheers for the quick answer. Do you think its safe to telnet the new image onto it? Seen it stated that rs232 is defo the way to go for safety. I do follow guides carefully though so hopefully i'd be able to avoid any box frying errors. If not then i'll have another rummage through my old cables then buy one as a last resort (yes i'm tight). Is it safe to test out connection with various rs232 cables i may have just incase one turns out to be a null modem or could that damage the box?
      • jonnyair
        • Mar 2009
        • 4
        Oh yeah
        Just thought id add that i do know this is a dreambox thread but i also know openmedia is basically a twin tuner dm500 so i thought it'd be ok to post in this section. It is isn't it?
        • jckw
          • 760
          null modem is the same cable m8 and u r in the right section u can flash via telnet but ive never done it that way
          • jonnyair
            • Mar 2009
            • 4
            Is that because there's a high risk of it going tits up? suppose i should try via telnet as it can always be recovered by rs232 if it fails is that right? And can i assume its safe to test the connection with any rs232 type cable that i might find? I'll stop asking questions in a minute
            • jckw
              • 760
              as i said m8 never tried telnet but there is plent of help here if you need it
