FY HD 800C-II
  • larlee
    • Sep 2012
    FY HD 800C-II
    Hi bros,
    Can anyone advise if this is also similar to Dreambox 800C?
    I am looking for the manual to record shows.
    Managed to open the files on PC but cannot play from the 800C itself.
  • uu161
    • May 2012
    • 372
    similar function
    it does play rec video on FY 800C-II just that media menu is sucks and not user friendly try to play around u should able to.
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
    • larlee
      • Sep 2012
      Originally posted by uu161
      similar function
      Hi uu161,
      thanks for the reply.
      does it means that I can record but unable to play it from the player but have to use another player to do it?
      • uu161
        • May 2012
        • 372
        Originally posted by larlee
        Hi uu161,
        FY 800C-II do rec and play no issue.
        go tool under media player u will find out
        FY 800C-II all rec video file are under ALIDVRS2 folder
        • swq26
          • Sep 2012
          • 4
          Is there any difference with the new mini fyhd 800c? Anyone using thhis? Got any new firmware? Can guide me? Appreciate it
          • Stevensp
            • Jun 2012
            • 6
            can your 800c-ii view the EPG?
