Co-Ax Wiring for a new Dreambox
  • porker
    • Mar 2009
    • 32
    VM are coming on friday to deliver a new STB and connect a co-ax to the back of my tv (cuurent coax runs upstairs for BB only and a second one ends outside for the phone)
    If i wanted a Dreambox upstairs can i lust cut the cable to the modem, fit F connectors and splitters and run co-ax to the STB?
    Cheers
    Porker
  • faulks6164
    • 55
    yes mate do just that
    • jckw
      • 760
      Cheers
      Porker
      dont cut cable get a 2 way splitter then the conections from maplin or other tech shop they sell the coax in 1.5m lengths with conections on
      we are all learning each day
      • porker
        • Mar 2009
        • 32
        Any reason not to cut n fit connectors? I need the new box to be about 5 meters from where the cable currently is. surely its better to only make 1 break and not join loads of small cables together?
        Porker
        • jckw
          • 760
          you can m8 but you can get different lengths of cable and buy your own screw connectors remember sat and cable coax is different to normal
          • porker
            • Mar 2009
            • 32
            Yeah i have no problem with which cabkle to use or fitting f connectors (done loads of sat stuff before) just wasnt sure if u could just split the cable feed like u can a terestrial coax, you cant just do that with sat feeds.
            Thanks for the advice
            Porker
