why will my dreambox not connect to pc anymore
  • thered
    • Aug 2008
    • 4915
    may be a stupid queation but my dreambox will not connect to my pc anymore and i dont understand why
    all the settings are the same i have also changed to different ip settings it wont work
    but my box can still download plug ins ect from the net so i know it is all ok but it just wont connect to pc at all
    btw also my box hung yesterday and wouldnt re-boot to the image i use on my cf card so i have installed a new image which is fine although i cant get my services to work as it wont let me connect
    btw dreambox 7025 is the box of desire
  • scuba
    • 198
    check if ur pc ip changed.
    • red devil
      • Oct 2008
      • 690
      ive got cables run from 3 boxes to my desktop and if i conn to db1 then the only way i can conn to db2 or db3 is to reboot or change the ip add each time even tho all boxes have the same ip add.
      • mattpillon
        • Mar 2009
        • 9
        it may be a firewall setting to be adjusted, if u can connect to the internet the connection is ok, if u cant connect to pc its probaly because of a firewall ( as long as your ip settings have not been cahnged)
        • pawnhawk
          • 26
          I had the same problem a few weeks ago, I had connected my dreambox through my router many times using windows XP. then the last time I cound not connect no matter how I tried.
          So I switched over to windows vista and bingo went in no problem, I think mine may have been firewall problems.
          • mattpillon
            • Mar 2009
            • 9
            reddevil, you can not connect 3 box with the same ip add to one router. every box must have is own ip, different from the others.
            this is a lan rule, its the same for computers
            • saytar
              • Mar 2009
              check ur ip's
              • red devil
                • Oct 2008
                • 690
                matt, I never said they were connected to a router m8, wat I said was "Ive got cables run from 3 boxes to my desktop"
                I am using crossover cables for a direct connection that is why they all have the same ip
                • thered
                  • Aug 2008
                  • 4915
                  thanks for all the advice guys i had to use crossover cable to pc to get it to work even though i used the same ip what a pain dont know why it wont connect though still
