which evocamd is more stable
  • jfish
    • 799
    I flashed my DM 500c with the PLI Jade 2 last night and installed 2.17 EvoCamd - didnt clear channels
    re-flashed and this time installed EvoCamd 2.13 and this cleared channel.
    anyone managed to get EvoCamd 2.17 working
  • red devil
    • Oct 2008
    • 690
    tried 2.17 like yourself and it wouldnt work
    ive tried em all and find 2.11 or 2.12 to be most stable
    • mrdude
      • 110
      Evocamd 2.17b works and updates for me fine - although I use an older one as it's much smaller and takes up less space in var.
      Evocamd 2.17b needs to be installed and the name needs to be evocamd in lowercase in needs to have attributes set at 755, also roms need to be in scce and attributes need to be set to 755 - keys need to be in keys and you need the following:
      Autoupdate.Key
      camd_cfg
      Keylist.txt
      rsakeylist
      All file names are case sensative.
      That's all folks.....
      Also evocamd 2.13 works best for cable - 2.17 just adds extra stuff if you're using it for sat tv.
      Suck my plums
      • andymc1s
        • 694
        Hi mrdude could you answer this for me when using dm500c do I need to have anything in the softam or is it just evocam and keys. As a check on the softcam file shows empty
        Regards Andy
        • mrdude
          • 110
          Regards Andy
          On the dreambox500 the reason it shows up as empty is because it looks in:
          /var/etc/plimgr/cams/
          for a file with the cam name - just make a blank file in notepad and call it evocamd (lowercase) ftp it to the above location - then when you reboot your box evocamd will show up in the softcamd menu.
          Technically you don't even need this file if only running 1 cam - but you won't be able to choose between cams if this file is not present.
          Suck my plums
          • andymc1s
            • 694
            Thanks mrdude for the explaination much appreciated.
            Andy
            • Krypton
              • 694
              2.17c works fine for me. i found 2.12 to be causing breakup on some channels, 2.17c fixed this
              Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
              Chuck Norris has two speeds: Walk and Kill
              There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
              Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
              Chuck Norris does not sleep: He waits
