Suddenly lost all channels help please
  • bennyboi
    • Mar 2009
    • 29
    DM500 Suddenly lost all channels help please
    All channels display service unavailable and now when i try to scan on my local service it says no transponders found... help please!!
    ps i have flashed the image, checked the wire still no joy
  • krazylegz
    • 2834
    are you paying for any sort of subscription?
    has anyone elses in the street went off??
    have you selected the correct area for the scan??
    PS3= krazylegz120282
    • cantona7
      • 936
      plug in your vermin box to double check you have got a signal getting through
      when the sea gulls follow the trawler,it is because they think sardines will be thrown into the sea
      • bennyboi
        • Mar 2009
        • 29
        i pay for xl
        my vermin box is still fine and all channels there
        i used the same scan as i did intially when i got all channels
        • bennyboi
          • Mar 2009
          • 29
          i dont know if this helps...
          i started with just a normal tv co-ax connector on the end of my cable and the dreambox worked, today i swapped this for an f-type to add the splitter to run both boxes and this is where it stopped working.
          The vermin box still works fine throught the splitter but not the dreambox.
          Now i have tried to replace the co-ax connector on the cable and try a direct run to the dreambox but still no joy... any ideas?
          • bennyboi
            • Mar 2009
            • 29
            just a wee update, i checked the box before work and still had the same issue, for some reason i decided to swap the scart lead back to the original one i had and bingo it seems to pick up transponders!
            cant check properly from work as it takes an age to select the correct area remotely so will confirm later tonight
            thanks to those that tried to help!
            bloody bizare if it is the scart lead that caused the issue
            • Krypton
              • 694
              never heard of scart lead affecting scanning, still saying that im sure one of the more technically minded boys may be able to confirm that signal leakage from the scart may cause this?
              Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
              Chuck Norris has two speeds: Walk and Kill
              There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
              Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
              Chuck Norris does not sleep: He waits
              • murph
                • Apr 2009
                is this a cable prolem or will it come to mmds aswell
                • Krypton
                  • 694
                  this is a cable problem in uk mate. nothing to do with whats happening with encryption in ireland
                  • bennyboi
                    • Mar 2009
                    • 29
                    no i work in IT and have never heard anything sooo ludicris but i have tested it again and confirmed that as the issue
