Null Modem Cable
  • soros
    • Mar 2009
    • 13
    Null Modem Cable
    Hi guys... this is a very noob question... I was told from the person whom I purchased a null modem cable (9-pin) that if both ends of the cable is female, the cable is confirmed a null modem cable and not a serial cable... is that true?
    cos i have tried connecting the said cable to my comp but somehow even after i power up, dreamup doesnt seem to respond at all..
    thanks in advance!
  • Krypton
    • 694
    well just looked at mine and whaddaya know? both ends female. surest way is to hook it up to a box mate
    Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
    Chuck Norris has two speeds: Walk and Kill
    There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
    Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
    Chuck Norris does not sleep: He waits
    • soros
      • Mar 2009
      • 13
      thanks for the quick reply... i have done exactly that.. tried connecting it to my pc and then loaded dreamup as the newbie guide instructed... but after powering the box, no response from dreamup.... i am wondering whether it is a wrong cable or the problem lies somewhere else...
      • bennyboi
        • Mar 2009
        • 29
        sounds like its true to me
        • Krypton
          • 694
          looks like its a serial cable and not a null modem cable, but have no fear you dont necessarily need dreamup or a cable to flash. you can use telnet with a crossover cable or a router
          and its quicker
          • soros
            • Mar 2009
            • 13
            i currently dont have a crossover cable... i just have the normal lan cable... you mentioned i can do it with a router.. do i need a crossover cable as well if i am using a router? if so, maybe i will go buy one tomorrow instead... thanks again!
            • Krypton
              • 694
              no if youve got a router, use two lan cables one from pc to router, the other from router to dreambox
              • soros
                • Mar 2009
                • 13
                oic.... and i use this Guide: Flash and Backup an Image via Telnet after i have linked up the cables accordingly right? you just made my day krypton! thanks a million!!!
                • Krypton
                  • 694
                  no sweat mate. follow the guide exactly and all will be well in the world
                  • soros
                    • Mar 2009
                    • 13
                    could you just bear with me for 1 additional question... how do i locate my ip address for my dreambox?
                    edit: i think i have found my ip address for dreambox by using the command arp -a at cmd prompt
                    however, when i type telnet ip.address, a command box came up with "Connecting ip.address....", after which the command box just disappear. there was no prompt for username nor password... any idea what went wrong? if its of any help, when i type arp -a, the "Type" for my dreambox ip address was indicated as "invalid" rather than "dynamic".
                    • Krypton
                      • 694
                      on your dreambox go to menu>setup>expert setup>communication setup.
                      your ip will be there
