Dreambox Dm500c dreamup software
  • Hydropyrus
    Help me pls!! i cannot connect the dreambox dm500c to dreamup 1.3.3.1 i tried every suggestions but it doesnt work hopefully you guys can help me with this problem ASAP Thx alot peeps
  • AVGAL
    • Jul 2011
    • 64
    then use the traditional desktop coms port to connect
    • Hydropyrus
      I dont understand? Can you elaborate on what you have just said ?? thx
      • ethankam
        • Sep 2012
        • 7
        She's saying that you should try using Com port (RS232) from old computer to connect. Reason being that usb-serial adapter may fail (in fact they failed most of the time unless you are lucky to buy a compatible adapter with a compatible driver). This should works most of the time unless you have fried your chip with a over Waltage power supply.
        • La Manita
          • Feb 2013
          • 25
          I use usb-serial cable and still can't connect and I have compatible adapter with a compatible driver.
          This killing me big time.
          • mticad
            • Jan 2013
            • 10
            Hi.. cable need to be a null-type, just like a serial console cable.
            • DBTraitor
              • Feb 2011
              • 616
              RS232 NULL MODEM CABLE
              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
