Guide: Setting up Recording to a PC or NAS
  • raysquid
    • Nov 2010
    #106
    IP address query
    Hi there....I am very new to the world of Dreambox.
    I am setting it up to record to my pc. There are refernces to ip address and usually is 192.168.etc.
    My pc is one of 4 and connected to a modem / router.
    When I do the command "ipconfig" on my pc I get 10.1.1.3. Is this the ip address I should use on the Dreambox configuration.
    Any help would be appreciated.
    Ray
    • frosr6
      #107
      trying to set up my external hard drive that is connected to my Netgear WNDR3400 router with usb cable. I can access the hard drive on my pc but not on my Dreambox 500s. In my router settings page i have 4 different options to access it. ftp, ftp via internet, Http, and Http via internet. what one should i use? My router has \\readyshare\USB_Storage listed as available folders. Im running PLI jade3 and am in the web interface trying to mount no luck. any help please?
      • *DP*
        • 4
        #108
        I got mine mounted and it started recording and then crashed the box. Any suggestions?
        • spink123
          • Nov 2010
          • 5
          #109
          Hi all,
          I read your post regarding setting up a HDD for recording and wonder if you can help me out.
          I am using a Buffalo Linkstation NAS but I couldn't mount it using the tutorial found in the thread:
          Here are my settings:
          I am using Newnigma2 image on my 800HD and I have created a folder "Recordings" in the root directory of my NAS. The username and password are the login details when I access the NAS from a web browser.
          Active: enable
          Local share name: Recordings
          Mount type: CIFS share
          Server IP: 192.168.2.7
          Server share: media/hdd
          use as HDD replacement: yes
          Mount options: rw
          Username: admin
          Password: ********
          Devilfish mentioned using SMBFS for NAS enclosure but I cannot find it in the mount type option. I can only choose between NFS and CIFS.
          Any help would be much appreciated, thanks..
          • nicholas88
            #110
            Need Help... I able to config to mount my drive to the dreambox but when recording the audio and video freeze every 2-3 seconds for a second when playback. Any tips ?
            Running PLi Image with PC i7 Processor with Windows 7. Tried on Windows XP also same problem.
            Anyone can help my problem...
            • siletto
              • Dec 2011
              • 14
              #111
              Need help setting up to record with Buffalo Linkstation Pro Duo
              I have gone through all the pages in this thread with no avail.
              Need help filling this page just to start off on the right track.
              Client directory:
              ServerDirectory:
              Remote Host Name/IP:
              I have given static address for my dreambox 500c (192.168.1.135) and NAS (192.168.1.203).
              I have created a folder (RECORDINGS) in my NAS web interface. Allowed for read & write mode. Guest access is enabled.
              • elvisc
                Hi I have problem to mount my drive on DM500S.
                Can anyone help me set the DM500S settings for mount drive?
                NAS is Buffalo TeraStation PRO TS-H2.0TGL/R5-EU
                My router IP: 192.168.1.1 (Netgear)
                DM500S IP: 192.168.1.10
                My NAS IP: 192.168.1.7 (only admin access for configuration, no file access)
                My NAS folder: \\NAS-001\DreamBox (shared folder)
                NAS user and password: dreambox
                My problem is that with IP I not have access to shared folder, I need to use Network manager to access files and folders.
                How can I set this on DM500S?
                Anyone have any solutions?
                • alpha786
                  • Dec 2011
                  • 6
                  #113
                  Help
                  when i do this i get a error message can any on help
                  • pigimakos
                    • Mar 2012
                    Hi guys,
                    i need yr help to setup my stuff....
                    1. i have dreambox 500s and i want to record directly to NAS (Synology DS212J)
                    2. on my synology i have a shared folder "Downloads" in which i want my recordings go in .
                    the location is :
                    i. smb://192.168.2.9/Downloads
                    ii. \\PGM_DISKSTATION\Downloads
                    My questions are:
                    1.on the add mount point window filestystem i will choose 3= smbfs, right ?
                    2. automount check , right ?
                    3. client directory and server directory , how i will enter the location ?
                    4. ip : the ip of the NAS
                    5.user name , pass - selfexplanatory
                    it has some boxes on the right, should i check some of them ? the last 4 are checked .....
                    Sorry for my noobs questions ((
                    Thanks in advance for yr help guys .....
                    • jasdev
                      • Apr 2012
                      • 16
                      #115
                      guys how do I record to pc. first I am using Cnigma2 image.
                      so first thing I do is go to bluepanel>setup>automount editor>add. then I key in my ip address n set the rest.
                      after which I still cant record. reading the instructions, I do not have communications setup, so am I doing rightly?
                      • casper66m
                        • Jan 2013
                        thanks man
                        • ivony
                          • Jan 2013
                          #117
                          What is the format of the recorded media?
                          Can I setup or configure the recording format type?
                          Thanks.
                          • uu161
                            • May 2012
                            • 372
                            #118
                            Thanks.
                            TS Format
                            no u can't only TS
                            if not use video converter to any format you wish to
                            if you like the post use the Like button located bottom right corner of each post
                            if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                            • smackinghar5
                              • Aug 2013
                              • 7
                              #119
                              NEED HELP!!!
                              I cant mount to my network drive using engima2 image.
                              Anyone can help ?
