Guide: Setting Parental Lock on your Dreambox
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    How Do I Hide/Lock Bouquets On An Enigma Image?
    For this example, we will use the Adult bouquet to lock and hide.
    • Select Setup menu then Parental Lock
    • Select Parental Lock button and change pin to what you want and re-enter
    • Select Save
    • Select Service Organising
    • Select Lock/Unlock Services
    • Enter pin code
    • Select Adult bouquet then select NO to lock it
    You should have a padlock icon next to the bouquet now. You will be prompted to enter the pin when selecting this bouquet.
    If you now want to hide the bouquet from the list...
    Setup > Parental Lock > Hide Locked Bouquets > Save
    How Do I Lock A Single Channels On An Enigma Image?
    • Select Save
    • Exit menus
    • Press OK then RED (All Services)
    • Scroll to channel you want to lock
    • Press MENU
    • Select Lock
    Now even if the box is rebooted that channel will always be locked.
    If the box is rebooted on a locked channel, it will ask for the unlock code on bootup.
    How Do I Unlock A Single Channels On An Enigma Image?
    • Scroll to channel you want to unlock
    • Press MENU
    • Select Unlock
    • Enter Unlock Code
    Good Luck!
  • Glasgowguyno1
    • 20
    great information, especially if you have kids, cheers
    • gillyflipper
      • 9
      when i unplug from the mains, the locked channels reappear when reconnected, is there anyway to prevent this? Just incase the teenager gets wise to this
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        After you have locked a channel, reboot the box via the shutdown menu. This will save the settings to the config file, now even if the box is unplugged, it will still have the lock when it's rebooted.
        • jake1970
          • 135
          help again
          i think im nearly finished but stuck now on what im sure is the post easiest problem to solve i cant seem to work out how to lock channels or bouquets ive got young kids about and really need to lock the adult content im using a 500c with the DW_V2.0_MODDED WITH NEW ROMS image
          thanks again
          dreambox 500c
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            Everything needed to lock them is in the first post, there isn't anything else to offer.
            Follow it step by step, don't miss anything out, and it will lock.
            • mcmasterg
              • Feb 2008
              • 29
              kaos thanks mate very clear
              • bajan2nv
                • 4
                lost password
                how do u find code if u have forgotten password?
                • MILLWALLFC
                  • 173
                  Great tip its slightly different on a 600 box:-
                  Set parental controls and hide channels.
                  On TV channel
                  Go to Menu
                  Setup
                  System Settings
                  Parental Lock
                  Tick Parental Lock, setup lock and hide locked services, remember pin number or your have to reflash box.
                  Press Green to Save
                  Exit Back to a TV channel
                  Press Blue button
                  Go into Dreambox Settings
                  Bouquets
                  Click Red button to show all channels
                  Press enter on the channels you want to lock and hide.
                  reboot the box via the shutdown menu, IF YOU DON?T DO THIS IS SOMEONE PULLS OUT PLUG ON TV ALL CHANNELS WILL STILL SHOW AFTER.
                  • angelspeed05
                    • Jun 2009
                    goog
                    good stuff
                    • lolo500
                      • Oct 2008
                      • 9
                      Thanks, especially for the note about rebooting the box via the shutdown menu to save the settings to the config file.
                      • barbarossa1986
                        Greetings from barbarrossa,
                        I know how to lock the channels, and bouq. Is it also possible to lock "all services" (dreambox 500 ) . I have never shut down , does it open automaticly when i open it again after shutting down?
                        Thnks for your soonest advises,
                        • astropalmo
                          • 7
                          thanks devilfish, its a superb guide for newbies. excellent work.
                          • ms1699ms
                            • Jul 2010
                            • 14
                            hi buy new box when i open setup it ask me current setup pin i spend ?170 it work what i went backup?plz help
                            • marsafy1
                              • Nov 2011
                              dreambox 500
                              i locked channels but when i accedently go on one it ask for a pin code and when i enter 4 time any number there is a message (try anothr pin ) when repling no the channel is opened how can i lock channels firmly?
