How to setup Sata HDD with DM800HD?
  • Logger
    • Feb 2011
    • 92
    DM800 How to setup Sata HDD with DM800HD?
    Hi all,
    I am going to setup a SATA HDD for recording of my DM800HD.
    Please advice which type of HDD should i buy? HDD got many type like ESATA, SATA, Serial ATA? How should i draw extra power for the HDD. It seem like DM800 doesnt has extra power connector for HDD. I am confused, as the package come with a cable for sata to serial ATA with molex connector.
  • uu161
    • May 2012
    • 372
    why don't you use network mount to pc or nas?
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
    • ypvs125
      • Dec 2010
      • 506
      Originally posted by Logger
      Hi all,
      Use the supplied cable as shown in the picture above. The connector with red, black and yellow is the one supplying the power for the hdd and only use 2.5" hdd to fit in the cramp space of the dm800.
      • flye
        • Dec 2011
        • 22
        • Logger
          • Feb 2011
          • 92
          Ok I got it. I try the network mount. But unsuccessfully. I need to buy HDD. 320GB enough right? I using enigma 2 img file, I just let dm800 format itself or what should I prepare the setup?
          • VirtuallyMore
            • Dec 2012
            • 98
            Although in the network mountpoint manager it has an option to say "use as replacement HDD", I have tried all the popular images for this box and also never got it to show in the storage devices list.
            However, I do use my network mount (on my NAS) as a path for all recordings and other data like crossepg etc, and it works perfectly fine.
            The only reason I can see somebody for needing an internal hdd is for recordings of shows (if they don't have a networked resource they can save into instead) as a medium sized USB memory stick is more than enough as a local HDD replacement for things like plugins and plugin data.
            If you want some advice how to set up a mount point for storing records to see my post here:
            • uu161
              • May 2012
              • 372
              normally cause setting issue
              1) IP address
              2) dir path
              3) user and pwd
              4) set CIFS ( like what VirtuallyMore say )
              for my case CIFS or NFS will work on my synology nas
              • alienated
                • Mar 2012
                • 29
                If you already have a USB HDD, might as well use it than getting a new HDD.
                The process may not be 100% plug & play, it depends on the image, it may requires some manual installation. It should be easy if you know unix/linux command.
                • Logger
                  • Feb 2011
                  • 92
                  Yes I have USB HDD, that is my pc backup use. Anyway I had fix the 2.5 inch HD. Initialize the HDD n it works n start recording. Luckily me
