edit keys useing remote under DW?
  • yarps0
    • 5
    DM500 edit keys useing remote under DW?
    edit and change keys under DW1.6.5 or DW2.1 useing remote control?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    • mrdude
      • 110
      Originally posted by Devilfish
      LOL, I was thinking the same thing myslef m8.
      Suck my plums
      • yarps0
        • 5
        OK. sorry. How to change keys thru remote contol on Dm 500c under DW?
        • krazylegz
          • 2834
          why would you want to use remote...its far easier to use pc and edit them....also if you have the auto update rom fix then there is no need to update the keys as it does it by itself
          PS3= krazylegz120282
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            The image needs to have the key updater plugin installed. If it is, it will be accessible from the blue button menu. If it's not installed, you'll need to connect the dreambox to a PC to add the plugin, and if you're connecting it to a PC, you might as well add the latest roms to make it auto update so no need for the plugin really.
            • delboy13
              • 415
              you can use tuxbox commander if installed.click ok on tuxbox commander then go to var folder press ok.go to keys folder press ok.go to keylist.txt press 4.no highlight the key and press ok and you can edit it.much better to update the roms though
              • yarps0
                • 5
                devilfish and delboy13 many thx. If You knew only how to deal with lack of sky channels on cable in IRL
