Help with flashing dreambox 500 Newbie!
  • madmanc1973
    • Jan 2013
    • 7
    Hi Guys I need your help please,as I am a newbie but am having a go a flashing a new image to my dreambox 500.I did manage to flash images to my box with dream up without a problem,put when I do a transponder scan it wont lock to anything so what am I doing wrong?Also now when I try and flash an image it says error upload aborted,what have I done and how do I sort this out?it wont even connect through my modem on software updates when it did before,your help is appreciated as I am determined to flash this box,come on guys give me some help,cheers
  • madmanc1973
    • Jan 2013
    • 7
    No Help???
    Is there an unwritten rule on this forum where if your new to this then nobody will offer you any help or advice???
    • ASTROBOX
      • 163
      The answer is all here mate all u have to do is read the stickies to solve your problem.
      Here we don't spoonfeed members read 1st then try to do it on your own, always trial & error if u want to succeed.
      1st help for transponder issue, did u have the correct satellite or cable xml for your area? where do you reside & what box model satellite or cable?
      If you don't tell us all this how are we going to help u????????
      If you in SG then this is your answer
      For channel list
      For general
      & many more
      • goodlands
        • Mar 2012
        • 52
        Best guide
        The best guide for newbie would be this one from AVGAL
        [URL="http://www.digital-kaos.co.uk/forums/downloads/other/8/onewbie-singapore-guide-500c-800hd-800se-2452/"onewbie-singapore-guide-500c-800hd-800se-2452/[/URL]
        • madmanc1973
          • Jan 2013
          • 7
          Thanks for the replys guys Astrobox the box is a dream 500 which worked previously on cable for quite some time in the uk,I had no problems flashing images but recently when I try it keeps saying upload aborted?I appreciate your help and understand its trial and error and am determined to get it working,but as a novice I do need advice,many thanks
          • AVGAL
            • Jul 2011
            • 64
            upload abort is your usb adapter problem
            use a coms port to do flashing
            • madmanc1973
              • Jan 2013
              • 7
              Im not using a usb adapter im using serial cable and was able to flash images before but this just keeps saying upload aborted no matter what image I use?any ideas?
              • AVGAL
                • Jul 2011
                • 64
                then i suggest use dreamup 1.3.3.1
                DreamUP_ver1.3.3.1.zip
