TV and Dream box sound
  • Ballistic
    • Oct 2008
    • 243
    DM500 TV and Dream box sound
    Hi all,
    One to pick your brians , did think i see something similar to this posted before but cant find it.
    Basically my TV has to have the sound up in the 70's to get it to a decent level with the DM500. It also means when i put the Ps3 on COD4 nearly deathens the whole street
    Is there any where i can change this in the Cpanel
    Thanks for any info
    B
    "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
  • cactikid
    • 12017
    on the dreambox remote is the volume set too low,u should see on screen where volume is set too.
    • Ballistic
      • Oct 2008
      • 243
      I have tried to find a happy medium, If i have the DBox one say just below the red, the TV one has to be up nearly at full blast to get a decent level of sound.
      B
      • rickets
        • 135
        Well known problem m8. No solution.
        • Ballistic
          • Oct 2008
          • 243
          Cheers Rickets
          B
          • mjrrenegade
            • 49
            A decent quality scart cable might improve things. I ended up using the digital optical out into my home cinema system.
            • Motorsat
              • 27
              Yes, this is reportedly a problem and particularly annoying when switching back to TV mode causing deafening sound levels. If you a willing to throw some money at the problem, you could put a graphic equaliser between your Dreambox and the TV and use the 'gain' control to lift the overall sound level. Works even better if you have a surround sound system and you put the graphic equaliser in-line before the sound is fed to your amp. A decent graphic equaliser for the task would be the Citronic CQ-215 or for little more money (?85) the Citronic CQ-231. Another solution would be to add a 'pre-amp' but not seen many of those at reasonable prices.
              Dreambox DM500+, 85cm Hit-FESAT Dish, TM-2200 Super, Invacom 0.3dB Quad LNB, Triax DDU.
