DM500 can't be detected
  • brianzhang
    • Oct 2012
    • 5
    Hi bros,
    Need some help and advise!
    Recently my wife was mopping the floor while the DM500 dream box is showing. She accidentally pushed the switch cable wire which interrupted the electric supply to the dream box.
    She re-plug in the switch again but it doesn't work anymore. In the past, when we plug in the main supply switch, I noticed the power light will be in red and after awhile turn green and TV will detect the signal.
    Now, the power light just stay green and TV couldn't pick up any signal. Please advise how I can get it working again!
    I tried to unplug and plug in the cable again but the light is always green..
  • mtv1
    The Stig PT
    • 4413
    try a different psu m8 , any 12v 1.0 amp psu will do i've used one's off the christmas lights worked a treat
    • brianzhang
      • Oct 2012
      • 5
      You mean another power source?
      • Logger
        • Feb 2011
        • 92
        Originally posted by brianzhang
        Hi bros,
        That is the problem of DM500. You cannot just on and off. You must put in standby model (Red) then proper shut down. Try to do a reflash of the Dm500. You can check on the sticky how to reflash the image. But you never backup the magic file. Then too bad..
        Link for downloading the img file. Must FTP the magic file. The image without magic file.
        • mtv1
          The Stig PT
          • 4413
          psu = power supply unit
          they often get damaged or burn out most common fault .
          always worth checking before flashing as flashing erases all
