I have problem with an old 800 clone with sim 2.01 and bootloader # 59. If I get a new card sim 2 .10 I could install without Problems a new imag
Error no ca found,any image I try did not work.
i had the same problem with a dm800 clone box (Mbox800HD)
i used the yassinov tool NCF SIM2 v2.5 with a null modem cable its was easy to fix
just putt the correct bl in too the folder ssl-bt because the bl 84b isn't in the folder if your download the tool it go's till bl 82
when its fixed i used a older oe.1.6 image with the web browser flash i used black hole then when the flash is ready don't disconnect your box
the reflash only your bootloader the same way you flashed your image then after flashing is ready wait for 10 sec's then power down en reboot.
G.luck regards TeQuilla -
NO CA FOUND ERROR DVB800 HD PVR
Hi i have a dvb800 and it has the no ca found error.I have the patched dream up (forhike and natas one).First of all i have been told to use a patched image.Then i have read its a dm800 clone but you can use a normal image?.Pleas can someone put me in the right direction.I have tried to flash the bootloader 84b then an image which has 84b compatible.It says flashed ok but when i turn the power off disconnect the null cable and restart i get the sim201 team #84b error again.I have tried the ncf tool with sim 201 and right bootloader with no success.I have also tried ip address and the page comes up i can search for nfi file to flash but when i press flash nothing happens.Im so close to binning the dvb box.I really need a dummys guide.I really would appreciate some advice and help.On the ip dreambox site it says my bootloader version is second stage loader build #59.PLEASE PLEASE PLEASE im begging here for help.thanks in advanceComment
