help needed for black box 500
  • tanes1808
    • Feb 2013
    • 7
    Dear all, recently i enounter blank screen and remote does not response to the black box. Is it because SH has renew the channel? If so how shd i start to do it? Someone quote me $60 to do it. .pls help me
  • DBTraitor
    • Feb 2011
    • 616
    i quote you $0
    just reflash and everything back to normal
    reflash is the most basic you need to know... go read up
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • Koonz
      • Dec 2012
      • 63
      500c image
      Download 500Plijade3.img from Sendspace.com - send big files the easy way
      • tanes1808
        • Feb 2013
        • 7
        Hi I am a newbie in blackbox...how shd i start off after downloading the img.file?
        • tanes1808
          • Feb 2013
          • 7
          Originally posted by DBTraitor
          i quote you $0
          Hi DBtraitor..can i know which sticky forum i should start reading instead? It is easy to reflash for a newbie like me??
          • AVGAL
            • Jul 2011
            • 64
            Digital Kaos - Downloads - ONewbie! Guide for Singapore 500c/800hd/800se
            • tanes1808
              • Feb 2013
              • 7
              Dear expert,
              After reading the forum, the step i needed to do is
              1) buy a null modem
              2) dl dreamup program 1.3.3.1
              3) dl image file of 500Plijade3 image
              4) ethernet cable =>need this?
              connect to desktop=>install dreamup=>connect nullmodem from PC to black box ==>Guide: Flashing a Dreambox with Dreamup
              Is my understanding correct? Is there anything i miss out or i need to take note?
              Thank you in advance
              Go to Page...
              • SGDVB
                • 210
                How long have you use thos blackbox? I think the flash chip is giving you problem. Even if you reflash, the image may drop very soon.
                Suggest you get the chip change.
                • zee24
                  • 3342
                  ive just bought one from aliexpress will be arriving within next 3 weeks hopefully because of the chinese new year. Anyway I'll need all your help when it arrives by the looks of it, but I'll follow the above links first.
                  • tanes1808
                    • Feb 2013
                    • 7
                    hi SGDVB. i have this prob for 1 week. but my sister black box who bought the same time with me also having the same problem. In this case how should i do? flash or change chip?
                    i use this box for only 1 year..
                    • SGDVB
                      • 210
                      You can reflash but i cant say if it will last till the image drop again.
                      • SGDVB
                        • 210
                        Think by the time your box arrive, all box will be down due to the new upgrade (N3).
                        • AVGAL
                          • Jul 2011
                          • 64
                          box from aliexpress will take only 4-5 days to reach you...
                          • zee24
                            • 3342
                            cheers for that I know this is true usually but it's Chinese New Year the guy I bought it off told me the mail services are on holiday until the 18th so won't be posted out until then.
                            • zee24
                              • 3342
                              you sure about this? i thought no one knows when this will happen what makes you think it will be in a few weeks?
